Reading 0-100 mV signal Pressure Transducer
I have a 4 wire pressure transducer (Power, ground, output pos, output neg) that I am using to read hydraulic cylinder pressure. But I'm having problems understanding how to read that off the analog voltage on an Arduino Mega 2560. How would I code that and how could I wire that if analog only reads off one pin, no ground?
Here is the code I have so far, I have it reading out on a LCD display and eventually it will be reading weight from that pressure and be able to zero the weight (like a scale)
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
int pin5 = A5;
int pin0 = A0
int Tare = pin0
void setup() {            //This function gets called when the Arduino starts
  Serial.begin(9600);     //This code sets up the Serial port at 115200 baud rate
  lcd.begin(16, 2);
  lcd.clear();
  pinMode(pin5, INPUT);
void loop() {             //This function loops while the arduino is powered
  int val;                //Create an integer variable
  int weight;
  float Tare = 0;
  weight = analogRead(pin5)*(5/1023);
  val = (analogRead(pin5)*(5/1023))*10; //the value to the serial port
  Serial.println(weight);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Pressure=");
  lcd.print(val);
  lcd.print(" psi");
  lcd.setCursor(0,1);
//  lcd.print("Weight =");   //Code for changing pressure to weight
//  lcd.print(weight);         //Commented out for now till I figure out the math
//  lcd.print(" lb");
  float voltage = analogRead(pin5)*(5/1023);
  Serial.println(voltage);
  lcd.print("volts =");
  lcd.print(voltage-Tare);
  if(tare == HIGH) Tare = voltage;
  delay(750);            //Wait one second before we do it again
Have you try a Load Cell Amplifier - HX711. That's allows you to easily read load cells to measure weight. It is made for small signal.
You need some sort of differential amplifier for that sensor. The HX711 might work.
A common ground is required.
Hi, @tyler-stoltenburg17
Welcome to the forum.
Can you please post a link to data/specs of the pressure transducer?
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
https://www.mouser.com/ProductDetail/824-M302100000505KPG
I agree with the HX-711. The lowest gain (32) you should work fine for your voltage range.
