Reading 10 inputs using the Arduino pins
I just bought an arduino and I have gone over the tutorials so i became familiar with inputing and outputing signals so far..my next step is to read 10 input signals(function generator will supply the same signal to all pins of the arduino simultaneously). I have an arduino mega so it has plenty of pins(15) and I would hope somebody had a similar experience. How can i proceed. do i just declare all the 10 pins i will be using as inputs and display a message for each input being read but then how do i know which input has been read do i create a variable to store each read input ; ex: val for pin1 and val10 for pin10 etc..am i on the right track here? thank you in advance
Are you trying to output anything? Are you just trying to have 10 inputs?
A mega had 54 pins… Where did you come up with 15?
You can do a constant byte:
const byte BUTTON[10] = {53, 52, 51, 50, 49, 48, 47, 46, 45, 44};
And then pinMode:
 for (int i = 0; i < sizeof(BUTTON) / sizeof(BUTTON[0]); ++i) {
 pinMode (BUTTON[i], INPUT);
Yes your are right the arduino mega has 54 pins but i meant 16 pins for the analog pins:)
As far as outputs, all the 10 inputs will have to control one led and it works like this:
the output pin goes as a signal to the base of a transistor that plays the role of a switch. the collector of the transistor goes into the LED and this LED is hooked to a VDD=5v and the emiiter of the transistor goes into a 1k resistor which is hooked to the GND. so the 10 inputs will control the same LED through the transistor..Now whether I have to use an analog or digital pin output I don't know which is better for this application but i'm sure a lot of you guys out there would know better than I do..thank you for taking the time to answer my Qs
You haven't got any analogue outputs, but the PWM digital outputs can be used to control the brightness of your LEDs.
