Reading 2 characters of serial
I currently have 14 buttons connected to one arduino. When one is pressed, it sends the 2 character number of the button (00-13) to the other arduino via softwareSerial on the analog port.
The transmitter is working properly but i’m having trouble on the receiving side. I’m using this code:
#include <DigitalToggle.h>
#include <NewSoftSerial.h>
int serial = 0;
NewSoftSerial mySerial(A5, A4); // RX, TX
void setup(){
int pin = 0;
while(pin < 14){ pinMode(pin, OUTPUT); pin = pin + 1; }
mySerial.begin(9600);
digitalWrite(1, HIGH);
digitalWrite(0, LOW);
void loop(){
if (mySerial.available() > 0) {
int no1 = mySerial.read() -48;
int no2 = mySerial.read() -48;
if (no1 == 1)
no1 = no1 +9;
serial = no1 + no2;
} else if (no1 == 0) {
serial = no2;
Serial.println(serial);
digitalToggle(serial);
But all it sends to my PC is rubbish, often -49 or -39.
I think i need to do everything with a buffer but i don’t know how…
Usual problem - see if there is at least one character available, then read both of them.
A while loop is typically used to loop an indeterminate number of times. A for loop is typically used to loop a defined number of times. This would make more sense as a for loop.
Why are you diddling with the Serial port pins?
If there is at least one byte available, read them both. How’s that working for you? Oh, never mind, you told us already.
Why not use:
int no1 = mySerial.read() - '0';
Much more obvious, don’t you think?
if (no1 == 1)
no1 = no1 +9;
serial = no1 + no2;
serial = no2;
Or
serial = no1 * 10 + no2;
That's because i have LED's on them (with jumpers that i remove when programming) but i need to toggle the LED's for them to be in the correct state
AWOL: Usual problem - see if there is at least one character available, then read both of them.
I already stated, i have no idea on how to read 2 characters over serial..
lyron:
Wait until there is at least two character and read twice.
Arrch: Wait until there is at least two character and read twice.
Thanks, will try now...
Allright, now i am using this code:
 if (Serial.available() > 1) {
int no1 = Serial.read();
int no2 = Serial.read();
if (no1 == 1) // to clarify: This is to combine the two values, if it's 10 or more, it will make no1 10 and add no2 and if it's less than 10 it will just make serial no2. This helps with the digitalToggle.
no1 = no1 +9;
serial = no1 + no2;
serial = no2;
in my loop.
I've uploaded the code but no matter what the arduino receives, it always responds with '0'.
Suppose you send '2', '3'. no1 will be 50, and no2 will be 51.
no1 = no1 +9;
serial = no1 + no2;
serial = no2;
So, if no1 is not 1, serial never gets assigned a value.
Are you reading these replies?
That's because when you type "10" into the serial monitor, you're receiving '1' and '0', not 1 and 0. If you want to get the actual value of the number that you typed in, subtract '0' from the character you read. This will convert '2' to 2, '7' to 7, etc.
You are using pins A4 and A5 to communicate in UART style. Maybe it's an opportunity for you to use the same two pins and communicate via I2C? This way you can add more devices without losing more pins.
You are currently trying to communicate between the two Arduinos using an ASCII based protocol. To transfer the state of 14 buttons a binary one may be more efficient, you need just one byte then and you don't have to deal with decoding ASCII characters back to binary values again.
The sending part would be then (still in SoftwareSerial style):
mySerial.write(pinNumber);
the receiving part:
byte pin = 255;
if (mySerial.available()) {
  int c = mySerial.read();
  if (c >= 0) {
    pin = c;
You can choose any other base (I used 0 as the number of the first pin), you just have to add the value on the sending side and subtract it on the receiving side.
Others may search the forum for answers
void setup(){
void loop(){
  if (Serial.available() > 0) {
    Serial.println (serialNumber());
long serialNumber(){             //any '-' will render the number negativ
  long number = 0;
  int sign = 1;
  while (Serial.available() > 0){
    char inc = Serial.read();
    if (inc == 45) sign = -1; // negativ number
    inc = inc - '0';
    if ((inc >= 0) and (inc <= 9)){
      number = number * 10 + inc;
    delay(10);
  return sign*number;
-Fletcher
