Reading 3 bytes from HC-05 Bluetooth Module
I'm trying to read from source that is constantly outputting 3 bytes at time. It should be a number between 0 and 60 and another number.
Here is code;
#include <SoftwareSerial.h>
SoftwareSerial MyBlue(0, 1);
unsigned long number2 = 0;
uint8_t *p = (uint8_t *)&number2;
uint16_t *pNumber2 = (uint16_t *)&number2;
  MyBlue.begin(9600);
  if (Serial.available()) {
    uint8_t number1;
    Serial.readBytes(p, 3);
    // store number, 8bits
    number1 = p[2];
    // clear high order 16 bits -- now number2 is just the low order 16bits
    p[2] = p[3] = 0;
    char buffer[512];
    sprintf(buffer, "number1: %hu, number2: %lu, *pu: %u", (uint16_t)number1, number2, *pNumber2);
    Serial.println(buffer);
The problem is that number2 is sometimes very large and number1 is sometimes zero. I don't understand why this is happening. I know the data is coming in very fast. Anything I am doing wrong? number2 should be between 0 & 60, and number1 should be 15. I have validated that client side is correct.
How it should work. Reads 2 numbers into 4byte buffer, unsigned long. One number is 8bits and the other is 16bits. I send them from Bluetooth client as 3 bytes. On the Arduino side, I read them into unsigned long, 3 bytes at a time; 4th byte is unused. Then assign (&buffer)[2] to 8 bit unsigned number, and &buffer to 16bit unsigned number (after clearing the most significant 16bits to 0).
Can anyone see what is wrong? Is it systematic of data coming in too fast?
Thanks!
Have a look at the Serial Input Basics tutorial, which among other things, shows you how to identify the start and end of a message, add separators so you can easily extract numbers, etc.
Using Software Serial on the hardware serial pins which you are also trying to use with the monitor is not going to be successful.
how can you guarantee that you always receive the 1st byte transmitted first
presumably you realize the code you posted is actually reading from Serial not MyBlue
i get the following when i enter "123" in the serial monitor
49 50 51  0 --  12849     51 -- number1: 51, number2: 12849, *pu: 12849
SoftwareSerial MyBlue (0, 1);
char buffer[512];
void setup () {
    Serial.begin (9600);
    MyBlue.begin (9600);
void loop () {
        uint8_t number1;
        Serial.readBytes (p, 3);
        sprintf (buffer, " %2d %2d %2d %2d -- ", p[0], p[1], p[2], p[3]);
        Serial.print (buffer);
        number1 = p[2];
        p[2] = p[3] = 0;
        sprintf (buffer, "%6ld %6d -- ", number2, number1);
        sprintf (buffer, "number1: %hu, number2: %lu, *pu: %u", (uint16_t)number1, number2, *pNumber2);
        Serial.println (buffer);
