Hellou, I have come to seek help with a problem I have been experiencing.
Currently, I am trying to send a 32bit Integer from an Arduino Mega 2560 to an Arduino Nano through serial comms. The number that is sent is expected to range from 0 - 99999 (as in five digits for a seven segment display).
Background: I am repurposing an old 7 segment display I found in an old arcade machine. I have code which allows the display to be driven. However, I need a dedicated Arduino to run it in order to get a smooth and flickerless display. So, another Arduino with more pins is running the main sketch and if anything changes to, let's say a highscore, it is sent through serial to the Nano and is then being updated and displayed on repeat without delays.
So far, my biggest concern is just this bit, where I am reading the 32bit Int from serial.
Because a friend recommended it to me, I also asked ChatGPT for help. It did help in creating a few approaches and fixing minor bugs, but in the end it was still not working.
This means I have no working code yet, sadly. And this is why I am asking here if anyone knows an alternative and definitive way of catching this number to display it.
The function which changes the displayed number requires a uint32_t input.
Right now, when the Nano receives a number higher than 32767 it is causing an overflow and returns just that. I know it's ther "toInt()". It's just that I have not found a solution for it.
int lastValue = 0; // Saves the last value
Serial.begin(115200); // Initialize serial communication
Serial.println("Hello!");
if (Serial.available()) { // Check if at least 1 character is available
String inputString = Serial.readStringUntil('\n'); // Read the string until the '\n' delimiter
if (inputString.length() >= 1 && inputString.length() < 7) { // Check the length of the input string
long newValue = inputString.toInt(); // Convert the string to an integer
if (newValue != 0 && newValue != lastValue) { // Check if the new value is valid and not equal to the last value
lastValue = newValue; // Update the last captured value
Serial.print("Neuer Wert: ");
Serial.println(lastValue); // Print the new value on the serial monitor
// this is where i would tell the LED display to update itself
delay(5);
For testing purposes, I have a Mega 2560 set up next to it with a small sketch to constantly supply five digit numbers. It is connected via Serial1 (RX1 and TX1) to the RX and TX of the Nano.
uint32_t num = 99900;
Serial1.begin(115200);
if(num >=99999){
num = 99900;
}else{
num++;
Serial1.println(num);
Serial.println(num);
Please, any help would be greatly appreciated.
Thanks in advance.
