Reading a 5v distance sensor using a 3.3v Arduino Pro Mini
Actually if you look at the data sheet it shows a peak Vo of just over 3v at 3cm. And the other graph shows a Vo of between 2v7 and just under 3v depending on the reflectance.
So what you are seeing is about right, and it looks like you don't need the divider.
Rob
