Sorry about this but I could use some more help,
The code below now compiles but setting the state of V7 does not operate the overRide function.
Would some kind soul explain why this doesn’t work as I’m pulling my hair out!
/* Comment this out to disable prints and save space */
//#define BLYNK_PRINT Serial
#include <LiquidCrystal.h> // include the LCD library
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); // control the LCD via Arduino pins 12, 11, 5, 4, 3 & 2
int timeState = 0; // ensure timer input is off on power up
int overRide = 0; // ensure the override input is off during power up
#include <ESP8266_Lib.h> // include the ESP8266 wifi chip library
#include <BlynkSimpleShieldEsp8266.h> include the Blinky wifi chip library
#include <TimeLib.h>
#include <WidgetRTC.h>
const int tempPin = A0; // create an integer called tempPin & asign it to Arduino analog input 1
int overRideValue;
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "!!!!!"; // authorisation token from Bylnk app
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "!!!!!"; // wifi network name
char pass[] = "!!!!"; // wifi network password
// Hardware Serial on Mega, Leonardo, Micro...
//#define EspSerial Serial1 // remove initial // if communicating with wifi chip via hardwired serial
// or Software Serial on Uno, Nano...
#include <SoftwareSerial.h> // communicate with wifi chip via software serial
SoftwareSerial EspSerial(A4, A5); // communicate with wifi chip using Arduino pins A4 (Rx) & A5 (Tx)
#include<SPI.h> // include library SPI, WidgetLED commands below don't work without this library
WidgetLED led1(V2); // asign led1 to Blynk virtual pin 2
WidgetLED led2(V3); // asign led2 to Blynk virtual pin 3
// Your ESP8266 baud rate:
#define ESP8266_BAUD 19200 // set wifi chip baud rate to 19,200
ESP8266 wifi(&EspSerial);
BlynkTimer timer;
WidgetRTC rtc;
void clockDisplay()
// you can call hour(), minute(), ... at any time
// please see Time library examples for details
String currentTime = String(hour()) + ":" + minute() + ":" + second();
String currentDate = String(day()) + " " + month() + " " + year();
Serial.print("Current time: ");
Serial.print(currentTime);
Serial.print(" ");
Serial.print(currentDate);
// Send time to the App
Blynk.virtualWrite(V4, currentTime);
// Send date to the App
Blynk.virtualWrite(V5, currentDate);
void blinkLedWidget() //
if (digitalRead(7) == LOW) { // if digital output 7 is off
led1.off(); // turn off led1 on Blynk app display
led1.on(); // if digital output 7 is on turn on led1 on the Blynk app display
{ if (digitalRead(8) == LOW) { // if digital output 8 is off
led2.off(); // turn off led2 on Blynk app display
led2.on(); // if digital output 8 is on turn on led 2 on the Blynk app display
void myTimerEvent()
// You can send any value at any time.
// Please don't send more that 10 values per second.
Blynk.virtualWrite(V1, millis() / 1000); // write to the Blynk app display every second via virtual pin 1
void temperature()
int tempRaw = analogRead(tempPin);
float temp = (tempRaw / 1024.0) * 5.0;
int Temperature = (temp - .5) * 100; // convert the floating value (3 deciaml places) to an integer (0 decimal places) for the Blynk app display
Blynk.virtualWrite(V0, Temperature); // write the value of Temperature to the Blynk app via virtual pin 0
// Debug console
// Set ESP8266 baud rate
EspSerial.begin(ESP8266_BAUD);
delay(10);
Blynk.begin(auth, wifi, ssid, pass);
// You can also specify server:
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
//Begin synchronizing time
rtc.begin();
Blynk.run();
// Setup a function to be called every second
timer.setInterval(1000L, clockDisplay);
timer.setInterval(1000L, myTimerEvent);
timer.setInterval(6000L, temperature);
timer.setInterval(1000L, blinkLedWidget);
pinMode(6, INPUT); // Pin 6 is a spare digital input (was for timer)
pinMode(7, OUTPUT); // Pin 7 is output for heat lamp 1
pinMode(8, OUTPUT); // Pin 8 is output for heat lamp 2
pinMode(9, INPUT); // Pin 9 is for the override switch
lcd.begin(16, 2);
BLYNK_WRITE(V7)
overRideValue = param.asInt();
if (param.asInt() == 1) {
overRide == HIGH;
overRide == LOW;
int tempRaw = analogRead(tempPin); // tempRaw is unprocessed value of the analog input
int Temperature = (temp - .5) * 100; // convert the float value (3 decimal places) to an integer (0 decimal Places) for the LCD
Blynk.run();
timer.run(); // Initiates BlynkTimer
//overRide = digitalRead(V7); // if the override switch is on
if (overRide == HIGH) {
lcd.setCursor(0, 0);
lcd.print("System is in "); // display this message on the LCD
lcd.setCursor(0, 1);
lcd.print("override! ");
digitalWrite(7, HIGH); // turn on heat lamp 1
digitalWrite(8, HIGH); // turn on heat lamp 2
else { // if the the override swich is off run this script on both serial & LCD & execute the program
lcd.print("Temperature is: ");
lcd.print(Temperature);
lcd.setCursor(2, 1);
lcd.print(" Degrees");
timeState = (hour() == 5 && minute() >= 30) || (hour() >= 6 && hour() < 18);
if (timeState == false) { // if it's night time
digitalWrite(7, LOW); // Turn off heat lamp 1
digitalWrite(8, LOW);
}// Turn off heat lamp 2
else { // if it's day time
if (Temperature >= 30) { // if the temperatue is above 5 degrees
digitalWrite(7, LOW); // turn off heat lamp 1
digitalWrite(8, LOW); // turn off heat lamp 2
if (Temperature < 28) { // if the temperature is below 5 degrees
if (Temperature < 27) { // if the temperature is below 1 degree
