This should open in Notepad the current firing software imports in this format. The first lines on top (header) are
Nr,(order of fire command)
slave,(which slave is chosen-encoding section of Arduino sketch)
output, (this is the bank/cue section of the Arduino code)
Ignition time, (time the cue is fired)
breaktime(time effect is in the sky, not important for the sketch)
duration(effect duration not important for sketch)
delay( this is the prefire of ignition time, relected in the ignition time, not important)
the other headers are none relevant as well. Time is entered as 00:00:000 (minutes:seconds:tenths,hundreths, etc) I really hope you understood that just in case it does not open here is copy in quotes.
Nr.,Slave ID:,Output:,Ignition time:,Breaktime:,Duration:,Delay:,Description:,Position:,Angle:
1,3,1,00:01.000,00:01.000,00:00.000,0,,,
2,1,1,00:01.500,00:01.500,00:00.000,0,,,
3,3,9,00:02.000,00:02.000,00:00.000,0,,,
4,1,9,00:02.500,00:02.500,00:00.000,0,,,
5,3,17,00:03.000,00:03.000,00:00.000,0,,,
6,1,17,00:03.500,00:03.500,00:00.000,0,,,
7,3,25,00:04.000,00:04.000,00:00.000,0,,,
8,1,25,00:04.500,00:04.500,00:00.000,0,,,
9,3,2,00:05.000,00:05.000,00:00.000,0,,,
10,1,2,00:05.500,00:05.500,00:00.000,0,,,
11,3,10,00:06.000,00:06.000,00:00.000,0,,,
12,1,10,00:06.500,00:06.500,00:00.000,0,,,
13,3,18,00:07.000,00:07.000,00:00.000,0,,,
14,1,18,00:07.500,00:07.500,00:00.000,0,,,
15,3,26,00:08.000,00:08.000,00:00.000,0,,,
16,1,26,00:08.500,00:08.500,00:00.000,0,,,
17,3,3,00:09.000,00:09.000,00:00.000,0,,,
18,1,3,00:09.500,00:09.500,00:00.000,0,,,
19,3,11,00:10.000,00:10.000,00:00.000,0,,,
20,1,11,00:10.500,00:10.500,00:00.000,0,,,
21,3,19,00:11.000,00:11.000,00:00.000,0,,,
22,1,19,00:11.500,00:11.500,00:00.000,0,,,
23,3,27,00:12.000,00:12.000,00:00.000,0,,,
24,1,27,00:12.500,00:12.500,00:00.000,0,,,
25,3,4,00:13.000,00:13.000,00:00.000,0,,,
26,1,4,00:13.500,00:13.500,00:00.000,0,,,
27,3,12,00:14.000,00:14.000,00:00.000,0,,,
28,1,12,00:14.500,00:14.500,00:00.000,0,,,
29,3,20,00:15.000,00:15.000,00:00.000,0,,,
30,1,20,00:15.500,00:15.500,00:00.000,0,,,
31,3,28,00:16.000,00:16.000,00:00.000,0,,,
32,1,28,00:16.500,00:16.500,00:00.000,0,,,
33,3,5,00:17.000,00:17.000,00:00.000,0,,,
34,1,5,00:17.500,00:17.500,00:00.000,0,,,
35,3,13,00:18.000,00:18.000,00:00.000,0,,,
36,1,13,00:18.500,00:18.500,00:00.000,0,,,
37,3,21,00:19.000,00:19.000,00:00.000,0,,,
38,1,21,00:19.500,00:19.500,00:00.000,0,,,
39,3,29,00:20.000,00:20.000,00:00.000,0,,,
40,1,29,00:20.500,00:20.500,00:00.000,0,,,
41,3,6,00:21.000,00:21.000,00:00.000,0,,,
42,1,6,00:21.500,00:21.500,00:00.000,0,,,
43,3,14,00:22.000,00:22.000,00:00.000,0,,,
44,1,14,00:22.500,00:22.500,00:00.000,0,,,
45,3,22,00:23.000,00:23.000,00:00.000,0,,,
46,1,22,00:23.500,00:23.500,00:00.000,0,,,
47,3,30,00:24.000,00:24.000,00:00.000,0,,,
48,1,30,00:24.500,00:24.500,00:00.000,0,,,
49,3,7,00:25.000,00:25.000,00:00.000,0,,,
50,1,7,00:25.500,00:25.500,00:00.000,0,,,
51,3,15,00:26.000,00:26.000,00:00.000,0,,,
52,1,15,00:26.500,00:26.500,00:00.000,0,,,
53,3,23,00:27.000,00:27.000,00:00.000,0,,,
54,1,23,00:27.500,00:27.500,00:00.000,0,,,
55,3,31,00:28.000,00:28.000,00:00.000,0,,,
56,1,31,00:28.500,00:28.500,00:00.000,0,,,
57,3,8,00:29.000,00:29.000,00:00.000,0,,,
58,1,8,00:29.500,00:29.500,00:00.000,0,,,
59,3,16,00:30.000,00:30.000,00:00.000,0,,,
60,1,16,00:30.500,00:30.500,00:00.000,0,,,
61,3,24,00:31.000,00:31.000,00:00.000,0,,,
62,1,24,00:31.500,00:31.500,00:00.000,0,,,
63,3,32,00:32.000,00:32.000,00:00.000,0,,,
64,1,32,00:32.500,00:32.500,00:00.000,0,,,
