Reading a digital signal and DAC.
I am currently trying to convert a digital signal to an analogue signal using DUE.
I have connected DS18B20 (A digital sensor) to Due.
const int digitalInputPin = 26;
pinMode (DAC1,OUTPUT);
pinMode (digitalInputPin,INPUT);
int b;
for(int i=0; i<4096; i++)
b = digitalRead (digitalInputPin);// Read pin 26
analogWriteResolution(12); //12 bits resolution
analogWrite(DAC1, i); // output values of varible b at the Digial to analog converter
delayMicroseconds(14);
Serial.println (b);
while(0){ // loop goes forever
Will this code change the digital signal from the sensor and output analog signal according to temperature change?
Any help will be greatly appreciated.
Thank you
Yong
Well, there's no mention of "b" in the program statement, so I don't think you'll get anything related to b on the DAC output. You might get a nice ramp as i goes from 0 to 4096.
b = digitalRead (digitalInputPin);// Read pin 26 (I have connected DS18B20)
digitalRead() returns a digital single-bit value; the digital STATE of the particular pin. The DS18B20 is a sensor that reads the temperatures and sends the result using a SEQUENCE of bit transitions, NOT a single bit. you'll want to use a library that can handle chip, or at least the sequencing of the bits. There happens to be one here: Dallas Temperature Control Library - Miles Burton - Innovative engineering for pretty much anything (Hmm. I don't know whether this works on Due.)
Thank you for your reply!
That is the issue I am having for a while and I just don’t know how to go on about it.
I tried another method which was using Arduino Uno, MCP4725(DAC) and MCP9808(A digital temperature sensor).
The code below gives the data value in Hex.
Could you possibly explain a little more on this?
Thank you!
#include <OneWire.h>
OneWire ds(2); // on pin 2 (a 4.7K resistor is necessary)
void setup(void) {
void loop(void) {
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println(“No more addresses.”);
ds.reset_search();
delay(250);
return;
Serial.print(“ROM =”);
for( i = 0; i < 8; i++) {
Serial.write(’ ');
Serial.print(addr*, HEX);*
  • if (OneWire::crc8(addr, 7) != addr[7]) {*
  • Serial.println(“CRC is not valid!”);*
  • return;*
  • Serial.println();*
  • // the first ROM byte indicates which chip*
  • switch (addr[0]) {*
  • case 0x28:*
  • Serial.println(" Chip = DS18B20");*
  • type_s = 0;*
  • break;*
  • default:*
  • Serial.println(“Device is not a DS18x20 family device.”);*
  • return;*
  • ds.reset();*
  • ds.select(addr);*
  • ds.write(0x44); // start conversion, use ds.write(0x44,1) with parasite power on at the end*
  • delay(1000); // maybe 750ms is enough, maybe not*
  • // we might do a ds.depower() here, but the reset will take care of it.*
  • present = ds.reset();*
  • ds.select(addr); *
  • ds.write(0xBE); // Read Scratchpad*
  • Serial.print(" Data = ");*
  • Serial.print(present, HEX);*
  • Serial.print(" ");*
  • for ( i = 0; i < 9; i++) { // we need 9 bytes*
    _ data = ds.read();_
    _ Serial.print(data*, HEX);
    Serial.print(" “);
    Serial.print(” CRC=");
    Serial.print(OneWire::crc8(data, 8), HEX);
    // Convert the data to actual temperature*
    * // because the result is a 16 bit signed integer, it should*
    * // be stored to an “int16_t” type, which is always 16 bits*
    * // even when compiled on a 32 bit processor._
    int16_t raw = (data[1] << 8) | data[0];
    if (type_s) {
    _ raw = raw << 3; // 9 bit resolution default*
    * if (data[7] == 0x10) {
    // “count remain” gives full 12 bit resolution*
    * raw = (raw & 0xFFF0) + 12 - data[6];
    byte cfg = (data[4] & 0x60);
    // at lower res, the low bits are undefined, so let’s zero them*
    * if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms*
    * else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms*
    * else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms*
    * //// default is 12 bit resolution, 750 ms conversion time*
    celsius = (float)raw / 16.0;
    fahrenheit = celsius * 1.8 + 32.0;
    Serial.print(" Temperature = “);
    Serial.print(celsius);
    Serial.print(” Celsius, “);
    Serial.print(fahrenheit);
    Serial.println(” Fahrenheit");
    ROM = 28 88 84 82 5 0 0 6A
    Chip = DS18B20*
    * Data = 1 51 1 4B 46 7F FF F 10 FE CRC=FE*
    * Temperature = 21.06 Celsius, 69.91 Fahrenheit*_
