I was wondering if anybody has been able to read the DS18B20 with the teleduino API?
This is not possible because that API doesn't support OneWire devices (a link to the teleduino page would have helped us getting the necessary information faster). As all the source code is available you can add that feature yourself, though.
Thanks pylon for the information and sorry for omitting the link to teleduino. As for modifying teleduino, since the proxy service is controlled by them, I'm not sure that it is possible to add methods to the API but I haven't tried myself.
The application I currently use to read the DS18B20 doesn't use the one-wire library and does the one-wire gymnastics directly in the code. I hoped that a similar gymnastic could be done with the existing teleduino methods.
So my original question is now: "Has anybody successfully modified teleduino for use with one-wire devices?"
I haven't written, it's necessary to change the "API" (better protocol) but you need to change the code running on your Arduino. After reading the DS18B20 on the Arduino you can send it as an analog value to the proxy and receive it the same way but you loose resolution (10bit instead of 12bit). Do you really need the teleduino protocol so that this limitation is not invested too much?
