Reading a .HTML file from SD card
Hi guys,
i am trying to build a home automation system and i decided to “host” the webpage on the arduino so i have created an html file (index.html) and inserted it onto the SD card. From the serial monitor i can see that there is an error in opening file.
attached find the code for your info
trail1_html.ino (1023 Bytes)
I always load files on the SD card using a pc to prevent possible errors.
zoomkat: I always load files on the SD card using a pc to prevent possible errors.
Thats what i did, my problem is that my code can read a text and display the contents, but its not doing the same when i try using an .html file
In the below discussion I posted a project with the files that download from the SD card. You might check this and see if it will work for you.
http://forum.arduino.cc/index.php?topic=279849.msg1970392#msg1970392
Filenames on the SD card must usually be in 8.3 format so .html won't be recognized. Use .htm (and make sure there aren't more than 8 characters in the name)
Pete
