onisuk
March 22, 2015, 3:53pm
#1
hi! i've got a simple project that turns digital pins on and off to control a relay board.
am i correct in thinking that i cannon use digitalRead to find out the current state of the pins? as they are set to outputs to drive the relays....
id like to know the pin state so i can output an "ON" or "OFF" to my i2c display
cheers onis
MarkT
March 22, 2015, 3:54pm
#2
digitalRead () works anytime on any pin.
onisuk
March 22, 2015, 4:02pm
#3
ah I see, does it return a value like 1 for on and 0 for off ?
MarkT:
But if you’re the one doing the digitalWrite()s so you already know the state; you’re in charge of it.
onisuk
March 22, 2015, 4:09pm
#5
how would i code it then ? do i need to change a stored variable each time i use digitalWrite() ??
then later in the sketch when im writing to the the lcd i can read that variable ?
A better way is to always use the state variable in the digital write
boolean state = true;
digitalWrite(pin, state);
onisuk
March 22, 2015, 7:56pm
#8
ah so what is that doing ? when the digital pin is written high the boolean called "state" is then updated to true ?
and the opposite happens when its low ?
onisuk
March 22, 2015, 8:26pm
#9
basically ive got an RTC clock that reads the time and turns on a relay to put on a light …
//Light control
if (hour() > 7 && hour() < 20)
digitalWrite(lightPin, HIGH);
digitalWrite(lightPin, LOW);
this is my code so how do i read the state of “lightPin” so i can output to my display ?
all this help is very much appreciated
when the digital pin is written high the boolean called “state” is then updated to true ?
No nothing is updated. By simply writing the variable and then manipulating your variable you keep the two in sync.
You do not read it. You use the state variable to keep track of it.
state = HIGH;
digitalWrite(lightPin, state);
state = LOW;
The variable state is the state of the pin who’s value is given by the variable lightPin.
