Reading a pulse signal
Hi peeps, just starting playing with my Arduino and having lots of fun. .lol
I am after reading my speedo pulse on my car and am hoping someone could confirm if I’m doing it right.
I will be getting the pulse by using this direct to pin2
The code I have done so far is…
int inPin = 2;   // choose the input pin (for pulse count)
int val = 0;     // variable for reading the pulse count
int pulseval = 0; // variable for counting pulse
long currentmils = 0; // variable to hold current mills value
int currentspeed = 0; // holds current speed value (needs to be calibrated)
int ledPin = 13;                 // LED connected to digital pin 13
int ledval = 0;
  pinMode(inPin, INPUT);    // declare pushbutton as input
  currentmils =  millis();  // set current millis
  Serial.begin(9600); // using serial output so I can monitor whats going on.
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
void loop(){
  if ( val == digitalRead(inPin) ) {
        val = digitalRead(inPin);
      pulseval = pulseval + 1;
  if ((currentmils + 100) < millis()) { // runs every second, will shortern time once calibrated
        currentspeed = pulseval / 2; // current speed needs calibrating via GPS, but its a start
      Serial.print(currentspeed);
        if (ledval == 0 ) {
        digitalWrite(ledPin, HIGH);
        ledval = 1;
        digitalWrite(ledPin, LOW);
        ledval = 0;
        pulseval = 0;
I was going to use pulsein but this pauses the code and I need to add few other sensors as well.
For some reason <> doesnt seem to be accepted on == which is why I’m using
any advice would help
cheers
Steve
Try using != instead of <>:
if (val != digitalRead(inPin)) // if value is not equal to digitalRead(inPin)
Other than this I haven’t really looked at your code. I’ll take a closer look if you get stuck or try it out and observe problems you can describe.
  • Ben
I hope you have not wired it up as your schematic shows. Your Arduino will see 7.2V on its input pins at a 12V nominal input. Since an automobile electrical system can be 13.6V (or more) when engine is running, you will be putting ~ 8.25 into the inputs.
Reverse the resistors. You need to put 30K (or more) on the 12V side, and 20K (or less) to ground.
You may find the following link helpful: http://www.arduino.cc/playground/uploads/Learning/Level_shifting_4_arduino.pdf
It refers to a circuit diagram for making Arduino sense a 12+-volt signal.
Just to be on the safe side put a diode with the anode on the digital pin and the cathode on the Arduino's 5V line. This will clamp the signal to a safe level in case the 12V gets bigger (like it does when the battery is charging).
