I am using while loop to wait for a start signal in a subroutine and I was trying to monitor how long it was sitting in the loop as it needs to break and produce a fault if there is no signal within a few seconds. I set up a timer with an overflow and set a volatile byte variable that I load an led output that is flashing in the ISR as I saw that in an example. I can monitor the status fine until I try it within a loop? Going a different route I tried to use millis() and ran into the same issue. I also tried doing a digital read in the while loop of the led output within the ISR routine. It seems not to see it turning on and off? Currently just increment a variable and if it gets to 32700 it kicks out but this in not really enough time. Could use a double long but this just seems like a lame way of doing this. Any info on best way to monitor longer blocks of time within a while loop in a subroutine would be appreciated. Thankyou.
Post your code showing the things you've tried. Use code tags.
saladman:
Why? You just record the value of millis() or micros() at the time of interest and compare against it
later.
And yes, post your code, we can't mind-read!
I had to put things back together as I had a mess. So I load to board and it seems to be working now?
I thought I had tried all the logical things to make it work but obviously I had missed something simple. I am putting the code in for anyone like me who may run into problems. Thanks
#define ledPin 8
#define Swin 3
pinMode(ledPin, OUTPUT);
pinMode(Swin, OUTPUT);
// initialize timer1
cli(); // disable all interrupts
TCCR3A = 0; // Clean the registers
TCCR3B = 0;
// OCR3A = 32767; // set compare register to desired timer count
// TCCR3B |= (1<<WGM12); // added this to do CTC function
TCCR3B |= (1 << CS12) ;//| (1 << CS10); // Prescaler 1024
TIMSK3 |= (1 << TOIE3); // enable timer overflow interrupt
// TIMSK3 |= (1 << OCIE3A); // enable timer compare interrupt
sei(); // enable all interrupts
ISR(TIMER3_OVF_vect) // interrupt service routine
//ISR(TIMER1_COMPA_VECT)
digitalWrite(ledPin, digitalRead(ledPin) ^ 1);
subx();
void subx()
int whatever = 0;
while(whatever == 0){
int readledstatus;
readledstatus = digitalRead(ledPin);
if ( readledstatus == 0)
digitalWrite(Swin, LOW);
if (readledstatus == 1)
digitalWrite(Swin, HIGH);
Except
for using
Tools + Auto Format
so your
code
doesn't
look like it was
typed by a drunken monkey.
OP, this code doesn’t do what you described in your original post. The function subx() never exits. Whatever you’re trying to do, this is a pretty convoluted way of doing it. Perhaps describe again what you want to accomplish?
Yes, but you never change the value of whatever inside your loop. It's a local variable in that function, so no other function (including the interrupt) can change it.
This may be what you intended. But if you really want a while loop which never exits, just write while(true)
So you want something like this?
const byte LedPin = 8;
const byte SwinPin = 3;
volatile boolean StartSignal = false;
unsigned long MaxStartTime = 5000; // StartSignal must be set within 5 seconds
unsigned long StartTime;
pinMode(LedPin, OUTPUT);
pinMode(SwinPin, OUTPUT);
TCCR3B = (1 << CS12) ; // Prescaler 1024
StartTime = millis();
ISR(TIMER3_OVF_vect) { // interrupt service routine
digitalWrite(LedPin, !digitalRead(LedPin));
StartSignal = true;
static boolean running = false;
// Wait for start signal from ISR
if (!running) {
if (StartSignal) {
running = true;
if (millis() - StartTime >= MaxStartTime) {
// ERROR: StartSignal did not get set in time
return;
} //end if (!runing)
// RUNNING. Do the stuff
Hard to see what value the timer interrupt brings to this application.
