Hi Hammy, thank you for your answer.
1 - I will look for some information about this interna voltage reference. =)
2 - Sorry about my links, my intention was to be more complete in information as possible.
3 - I don´t have schematic. This is a amateur project =/
My full code at the momment:
#include <SimpleTimer.h>
#include "EmonLib.h" //INCLUSÃO DE BIBLIOTECA
#include <RF24Network.h>
#include <RF24.h>
#include <SPI.h>
#include "printf.h"
//Função para resetar o arduino
void (*funcReset)() = 0;
// ***** CONFIGURAÇÕES DO LCD *****
LiquidCrystal_I2C lcd(0x27, 20, 4); // coluna, linha
//Definições do Radio
//RF24 radio(9, 10); // nRF24L01(+) radio attached using Getting Started board CONFIG NANO
RF24 radio(53,48); // nRF24L01(+) radio attached using Getting Started board CONFIG MEGA
RF24Network network(radio); // Network uses that radio
int channel = 10; //Canal do Radio entre 0 e 82 (Permitido Brasil)
const uint16_t this_node = 05; // Address of our node in Octal format ( 04,031, etc)
const uint16_t base = 00; // Address of the other node in Octal format
const uint16_t satelite1 = 01; // Address of the other node in Octal format
const uint16_t satelite2 = 02; // Address of the other node in Octal format
const uint16_t satelite3 = 03; // Address of the other node in Octal format
const uint16_t satelite4 = 04; // Address of the other node in Octal format
// ***** DEFINES *****
#define VOLT_CAL1 500.0 //VALOR DE CALIBRAÇÃO (DEVE SER AJUSTADO EM PARALELO COM UM MULTÍMETRO)
#define VOLT_CAL2 500.0 //VALOR DE CALIBRAÇÃO (DEVE SER AJUSTADO EM PARALELO COM UM MULTÍMETRO)
#define voltPin1 A6 //Pino de leitura da voltage1m para sensor voltage1
#define voltPin2 A7 //Pino de leitura da voltage1m para sensor voltage1
#define ampPin1 A0 //Pino de leitura da voltage1m para sensor voltage1
#define ampPin2 A1 //Pino de leitura da voltage1m para sensor voltage1
#define ampPin3 A2 //Pino de leitura da voltage1m para sensor voltage1
#define ampPin4 A3 //Pino de leitura da voltage1m para sensor voltage1
// ******** DEFINICAO DE UTILIZAÇÃO DE SENSORES ************
bool ampSensor1 = 1;
bool ampSensor2 = 0;
bool ampSensor3 = 0;
bool ampSensor4 = 0;
// ***** CRIAÇÃO DE INSTANCIAS *****
EnergyMonitor emon1, emon2, emon3, emon4; //CRIA UMA INSTÂNCIA PARA voltagem
//EnergyMonitor voltage2; //CRIA UMA INSTÂNCIA PARA voltagem 2
//EnergyMonitor current1; //CRIA UMA INSTÂNCIA PARA CORRENTE 1
//EnergyMonitor current2; //CRIA UMA INSTÂNCIA PARA CORRENTE 2
//EnergyMonitor current3; //CRIA UMA INSTÂNCIA PARA CORRENTE 3
//EnergyMonitor current4; //CRIA UMA INSTÂNCIA PARA CORRENTE 4
SimpleTimer timer; //TIMER
// ***** VERIAVEIS LOCAIS *****
int acVoltage1; //Tensão 110 V
int acVoltage2; //Tnesão 220 V
float Irms1;
float Irms2;
float Irms3;
float Irms4;
float IrmsTotal; //Corrente Total A
float acPower1; //Potencia 110 W
float acPower2; //Potencia 220 W
int acPowerInst; //Potencia Total W
int acPowerAcum; //Potencia Acumulada Kw/h
//Struct de TRANSMISSÃO com replicação das variáeis locais
struct payload_t { // Structure of our payload
int acVoltage1; //Voltagem 110 V
int acVoltage2; //Voltagem 220 V
float IrmsTotal; //Amperagem Total A
int acPowerInst; //Potencia Total Instantanea W
float acPowerAcum; //Potencia Total Acumulada Kw/h
//Struct de RECEPÇÃO
struct payload_r { // Structure of our payload
bool requestSAT;
void setup(){
//Inicializa monitor serial
Serial.begin(115200); //INICIALIZA A SERIAL
//ICICIALIZA TIMERS
timer.setInterval(2000, readAC);
timer.setInterval(2000, printSerial);
timer.setInterval(2000, printLCD);
//ICICIALIZA LCD E DA BOAS VINDAS
lcd.init();
lcd.backlight();
lcd.clear(); //Limpa o LCD
lcd.setCursor(2, 0);
lcd.print(" MATROX SYSTEM ");
lcd.setCursor(4, 2);
lcd.print(" AC MONITOR ");
//delay(2000);
warmUp();
montaLCD(); //Chama função para montar o layout do LCD
//DEFINIÇÕES DE LEITURA DA CORRENTE E TENSÃO
emon1.voltage(voltPin1, VOLT_CAL1, 1.7); //PASSA PARA A FUNÇÃO OS PARÂMETROS (PINO ANALÓGIO / VALOR DE CALIBRAÇÃO / MUDANÇA DE FASE)
emon2.voltage(voltPin2, VOLT_CAL2, 1.7); //PASSA PARA A FUNÇÃO OS PARÂMETROS (PINO ANALÓGIO / VALOR DE CALIBRAÇÃO / MUDANÇA DE FASE)
//Calibra cálculo de corrente (A)
emon1.current(ampPin1, 60.6); // Era 60.607
emon2.current(ampPin2, 55.0); // Era 60.607
emon3.current(ampPin3, 55.0); // Era 60.607
emon4.current(ampPin4, 55.0); // Era 60.607
//Inicializa RF24
SPI.begin();
printf_begin();
radio.begin(); //ATIVA A PLACA NRF24L01
radio.setPALevel(RF24_PA_MAX); //NIVEL DE POTENCIA DO AMPLIFICADOR PA NO MÁXIMO
radio.setDataRate(RF24_2MBPS); //VELOCIDADE DE TRANSMISSÃO EM 250Kbps
radio.setChannel(channel); //SELECIONA O CANAL 82 (DECIMAL) - ULTIMO CANAL LIVRE DA BANDA ISM NO BRASIL
radio.printDetails();
network.begin(channel, this_node);
void loop(){
// ***** TIMER GLOBAL *****
timer.run();
// Check the network regularly
network.update();
//Recebe dados do RF24
recebe();
//Serial.println(analogRead(0));
void recebe() {
while ( network.available() ) { // Is there anything ready for us?
RF24NetworkHeader header; // If so, grab it and print it out
network.peek(header); //Pega o próximo cabeçalho disponivel e trata
if (header.from_node == 0) {
payload_r payload;
network.read(header, &payload, sizeof(payload));
Serial.println(""); //Pula linha
Serial.print("Dados Recebidos de BASE: ");
Serial.println(header.from_node);
//Serial.println(payload.requestSAT);
if (payload.requestSAT == true) {
envia();
else {
Serial.println("Request false");
else {
void envia() {
Serial.print("Enviando dados para Base... ");
payload_t payload = {acVoltage1, acVoltage2, IrmsTotal, acPowerInst, acPowerAcum};
RF24NetworkHeader header(base); //destino, header type
header.from_node = this_node;
bool ok = network.write(header, &payload, sizeof(payload));
if (ok)
Serial.println("ok.");
Serial.println("failed.");
Serial.println("");
//FUNÇÃO PARA LEITURA DOS SENSORES AC
void readAC(){
//Calcula Sensor de Tensão 1
emon1.calcVI(17,200); //FUNÇÃO DE CÁLCULO (17 SEMICICLOS, TEMPO LIMITE PARA FAZER A MEDIÇÃO)
acVoltage1 = emon1.Vrms; //VARIÁVEL RECEBE O VALOR DE TENSÃO RMS OBTIDO
if(acVoltage1 <= 3){acVoltage1=0;} //Define Tensão para ZERO pela variação na rede sem o sensor.
//Calcula Sensor de Tensão 2
emon4.calcVI(17,200);emon4.Vrms; //VARIÁVEL RECEBE O VALOR DE TENSÃO RMS OBTIDO
acVoltage2 = emon4.Vrms; //VARIÁVEL RECEBE O VALOR DE TENSÃO RMS OBTIDO
//Calcula Sensor de corrente 1 se habilitado
if(ampSensor1 == true){
Irms1 = (emon1.calcIrms(1480)); // Calcula o valor da Corrente era(1480)
//if(Irms1 <= 0.3){Irms1=0;} //Define Corrente para ZERO pela variação na rede sem o sensor
//Calcula Sensor de corrente 2 se habilitado
if(ampSensor2 == true){
Irms2 = (emon2.calcIrms(1480)); // Calcula o valor da Corrente era(1480)
if(Irms2 <= 0.3){Irms2=0;} //Define Corrente para ZERO pela variação na rede sem o sensor
//Calcula Sensor de corrente 3 se habilitado
if(ampSensor3 == true){
Irms3 = (emon3.calcIrms(1480)); // Calcula o valor da Corrente era(1480)
if(Irms3 <= 0.3){Irms3=0;} //Define Corrente para ZERO pela variação na rede sem o sensor
//Calcula Sensor de corrente 4 se habilitado
if(ampSensor4 == true){
Irms4 = (emon4.calcIrms(1480)); // Calcula o valor da Corrente era(1480)
if(Irms4 <= 0.3){Irms4=0;} //Define Corrente para ZERO pela variação na rede sem o sensor
//Consolida todas as correntes na variável publica
float Irms110 = Irms1 + Irms2 + Irms3;
float Irms220 = Irms4;
IrmsTotal = Irms110 + Irms220;
//Calcula potecia para sensor de tensão 1 (110V)
acPower1 = Irms110 * acVoltage1; // Calcula o valor da acPower Instantanea para sensor 1 de 110V
//Calcula potecia para sensor de tensão 2 (220V)
acPower2 = Irms220 * 230; // Calcula o valor da acPower Instantanea para sensor 4 de 220V (usar variável acVoltage2 ou valor fixo)
//Consolida potencia total na variavel publica
acPowerInst = acPower1 + acPower2;
//Calcula consumo global acumulado de Potencia em KW/h
acPowerAcum=acPowerAcum+((acPowerInst/1800)/1000); //1800 para 2 segundos //3600 para 1 segundo.
void printSerial(){
Serial.println("REDE AC: ");
Serial.print("Tensão 1: "); //IMPRIME O TEXTO NA SERIAL
Serial.print(acVoltage1); //IMPRIME NA SERIAL O VALOR DE TENSÃO MEDIDO E REMOVE A PARTE DECIMAL
Serial.println(" V."); //IMPRIME O TEXTO NA SERIAL
Serial.print("Tensão 2: "); //IMPRIME O TEXTO NA SERIAL
Serial.print(acVoltage2); //IMPRIME NA SERIAL O VALOR DE TENSÃO MEDIDO E REMOVE A PARTE DECIMAL
Serial.print("Corrente 1: ");
Serial.print(Irms1);
Serial.println(" A.");
Serial.print("Corrente 2: ");
Serial.print(Irms2);
Serial.print("Corrente 3: ");
Serial.print(Irms3);
Serial.print("Corrente 4: ");
Serial.print(Irms4);
Serial.print("Corrente Total: ");
Serial.print(IrmsTotal);
Serial.print("Potencia: ");
Serial.print(acPowerInst);
Serial.println(" W.");
Serial.print("Acumulado: ");
Serial.print(acPowerAcum);
Serial.println(" KWh.");
Serial.println("");
//FUNÇÃO PARA IMPRESSAO NO LCD
void printLCD(){
//limpa dados do LCD
lcd.setCursor(8, 0);
lcd.print(" ");
lcd.setCursor(10, 1);
lcd.print(" ");
lcd.setCursor(10, 2);
lcd.print(" ");
lcd.setCursor(9, 3);
lcd.print(" ");
//Imprime novos dados do LCD
lcd.print(acVoltage1);
lcd.setCursor(12, 0);
lcd.print(acVoltage2);
lcd.print(IrmsTotal,2);
lcd.print(acPowerInst,1);
lcd.print(acPowerAcum,2);
void montaLCD(){
// coluna, linha
lcd.setCursor(0, 0);
lcd.print("TENSAO: ");
lcd.setCursor(16, 0);
lcd.print("V.");
lcd.setCursor(0, 1);
lcd.print("CORRENTE: ");
lcd.setCursor(16, 1);
lcd.print("A.");
lcd.setCursor(0, 2);
lcd.print("POTENCIA: ");
lcd.setCursor(16, 2);
lcd.print("W.");
lcd.setCursor(0, 3);
lcd.print("CONSUMO: ");
lcd.setCursor(16, 3);
lcd.print("KWh.");
void warmUp(){
readAC();
readAC();
readAC();
