Reading advertising data via arduinoble
Good morning, I have a Xiomi brand scale that has a ServiceData that sends the data
How can I get the data from the ServideData of the scale
Please help
Have you tried to connect your smart phone to it using Bluetooth?
if it is xiomi, which has its android app that consumes the data service and obtains the weight.
I want to use my arduino mkr wifi 1010 as a central and be able to obtain the weight
This is a code segment from noble (NODE.JS)
My question is how can I do the same but with ArduinoBLE
I hope your help
Thank you
Please post all the sample code, and don’t post multiple threads on the same subject.
You could be banned if that continues.
Ask a moderator to merge the existing threads.
Do you have an "ArduinoBLE"?
If so, the first step is to familiarize yourself with one or more of the BLE code examples.
I have merged your topics as too similar @advkael380 .
Please only create one topic for each distinct subject matter and be careful not to cause them to converge into parallel discussions.
The reason is that generating multiple threads on the same subject matter can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic. Someone might spend time requesting more information when that information is already available in the other topic.
Thanks in advance for your cooperation.
Start by learning to run example BLE programs on that platform.
I have already reviewed all the examples and none do what I require.
I need to obtain the data, but for this I need to access the data service and in this way obtain the data
As well as the fragment (NODE.JS) that does have the service data method implemented and in this way obtain the data
Of course not. Once you understand the programming language and library functions, you can take a working example and make the changes necessary to do what you require.
If you want someone to write code for you, post on the Jobs and Paid Collaboration forum section.
LOL.
Previously check the documentation about what the library offers and the functionality is still not available, I don't know why you take it that way, I'm seeing if someone could somehow access the data service. I can get the data but from the memory of the scale.
I am only asking for guidance because it is a functionality that is very common in sensors and other devices.
It shows that you do not know anything about it, and you answer nonsense things
