Reading an encoder with a third signal for 'homing'
I am using a stepper motor / encoder combo which has an added ‘Z’ signal for finding a home position.
link: https://www.digikey.com/product-detail/en/cui-inc/NEMA14-10-04D-AMT112S/102-4710-ND/9477637
datasheet: https://www.cui.com/product/resource/digikeypdf/nema14-amt112s.pdf
Using the encoder library works very well to read the A and B quadrature pulses, yet I haven’t found any examples of people using an arduino to read A B and Z to get pseudo-absolute position.
Ultimately, I would like to send the encoder data over i2c to a master board so as not to bog down the greater project with the interrupts from reading the encoder.
Do you know how I would go about reading the encoder normally, but if the Z pulse is detected, save that point reliably?
here’s an example of my code that reads A & B but doesn’t do anything with Z:
/* Encoder Library - Basic Example (modified by tman1733)
 * http://www.pjrc.com/teensy/td_libs_Encoder.html
#include <Encoder.h>
// Change these two numbers to the pins connected to your encoder.
//   Best Performance: both pins have interrupt capability
//   Good Performance: only the first pin has interrupt capability
//   Low Performance:  neither pin has interrupt capability
Encoder myEnc(2, 3);
//   avoid using pins with LEDs attached
long ePos = -999; // encoder position
union u_tag { // allow long to be read as 4 seperate bytes
   byte b[4]; // 4 bytes to be sent over I2C
   long LePos; // encoder position as 4 byte long
} u;
  Serial.println("Basic Encoder Test:");
  long newPosition = myEnc.read();
  if (newPosition != ePos) {
	  ePos = newPosition;
	  u.LePos = ePos;
	  Serial.print(u.LePos, DEC );
	  Serial.print(" = ");
	  Serial.print(u.b[0], HEX );
	  Serial.print(" : ");
	  Serial.print(u.b[1], HEX );
	  Serial.print(u.b[2], HEX );
	  Serial.print(u.b[3], HEX );
The union is there preemptively because it is how I will be sending the encoder value over i2c.
tman1733:
} u;
  Serial.println(“Basic Encoder Test:”);
  ePos = newPosition;
  u.LePos = ePos;
Assign one of your digital pins to the home signal and connect that wire to that pin.
Then in your “loop”, after this line," long newPosition = myEnc.read();",
read the home signal pin and if HIGH, save the newPosition as the home position.
Paul
