With an Arduino UNO R3, I was wanting to monitor 3 different inputs on 3 pins. With an interrupt I would have the ISR use a switch statement to call different functions.
I wanted to read a port register (Port B?) and using byte (low or high) read the value and use that for the cases.
My question is how do I read a port IO register and not just a pin read
I realised after posting the first link that although it mentioned the registers there was no detail on how to read individual bits. I considered editing the post to add the second link but you never know whether someone has already read a post so decided to add a second one
I was not clear on what or when the interrupts were used, sorry for not being clear.
I am using a DS3231 with the alarm triggering the interrupt at specific times. The ISR reads the alarm time to decide where to move a device to a new location.
There are 3 switch sensors for different positions and I wanted to read a group of pins (UNO-R3 pins 4,5,6 &7 which is grounded) and the correct binary value would let me know I have arrived. I would activate a motor drive relay using a while != value instruction. it seamed easiest to pass in the value associated with that position as part of the while instruction. Right now I am having trouble with the ISR routine. Ill be adding another question for that problem.
If you mean read from the DS3231, one cannot do I2C operations within an ISR.
This project is very unlikely to require interrupts, and we don't recommend that new users try, as the attempt typically introduces more problems than it solves.
The interrupt routine should only set an indicate the interrupt occurred. The loop() should check the indicator and do the actual processing. From one of my projects...
// volatile because it is shared with the interrupt routine
volatile boolean timerInterupt = true; // force initial processing
const uint8_t INTERRUPT_PIN = A7; //Mayfly defaults the RTC interrupt to pin A7
* Interrupt service routine for interrupt from RTC
ISR(PCINT0_vect) // Predefined name for interrupts on Port A, PCINT0 - PCINT7
// Keep this as short as possible.
if (!digitalRead(INTERRUPT_PIN)) {
timerInterupt = true; // we are only interested in the high to low change
// In loop()
// Handle RTC interrupts
if (timerInterupt) {
// This clears the interrupt flag in status register of the clock
// The next timed interrupt will not be sent until this is cleared
// get alarm flags - note that this may generate a low to high pin change interrupt
DS3231AlarmFlag flag = Rtc.LatchAlarmsTriggeredFlags();
LOG_DEBUG( << "Alarm flags " <<flag << endl);
// Get current date/time
present = Rtc.GetDateTime(); //get the current date-time
if ((flag & DS3231AlarmFlag_Alarm1){ // Handle data collection interrupt
// much later....
if (flag & DS3231AlarmFlag_Alarm2) { // Handle WiFi sleep timer interrupt
I noticed that you are using the RTClib library and I am using the wire library. I tried to use the RTClib, but I was having issues (Ignorance on my part).
I will try and do what you suggest with setting a flag
I use this RTC library. Others may have different options.
// Real time clock
#include <RtcDS3231.h> // from "Rtc by Makuna" in library manager
RtcDS3231<TwoWire> Rtc(Wire); // Construct RTC object
In setup()
Wire.begin(); // Set up I2C base functions
// Set up real time clock/calendar
Rtc.Begin();
Rtc.SetIsRunning(true);
Rtc.Enable32kHzPin(false);
Rtc.SetSquareWavePin(DS3231SquareWavePin_ModeAlarmBoth);
