Reading analog input into binaray array
Hello
Im wanting to read a value from the analog inputs for 0-1024 and convert it to binaray and then be able to read this and make a pin go high or low depending on wether it is a 0 or 1 with a delay between each bit
Im wanting to
You have permission, you don’t need to ask.
That would be an eleven-bit conversion.
You meant 1023, I assume.
int val = analogRead(aPin);
for(byte i = 0; i < 10; i++){
  digitalWrite(dPin, (val & (1 << i)) != 0);
  delay(millis);
Umm, I assume this is what you wanted?
If this doesn’t work, you get what you pay for. You have to comment it yourself.
int sensorPin = A0;
int ledPin = 13;
int sensorValue;
const int analogRange = 1024;
int shiftMask;
  pinMode(ledPin, OUTPUT);
  sensorValue = analogRead(sensorPin);
  for (shiftMask=1; shiftMask<analogRange; shiftMask<<1)
  digitalWrite(ledPin, sensorValue & shiftMask);
  delay(50);
  digitalWrite(ledPin, LOW);
shiftMask<<1)
should be
shiftMask<<=1) ?
Ps991:
shiftMask<<1)
should be
shiftMask<<=1) ?
Yes
