Reading analog value from IR Receiver
Hi I currently bought a pair of these to make a IR barrier and I want to detect when it is broken.
http://www.ebay.ie/itm/5mm-IR-LED-Pair-Infrared-TX-RX-transmitter-receiver-Diode-x-2-Pair-/261666210619?
The problem is I cannot get a value from the IR Receiver has anyone any idea on how to hook this up? Here are the specs from the Ebay page.
Specifications:
Transmitter (Tx):
Power: 0.1W.
Maximum Current (Approx): 0.5mA.
Launch Angle (Approx): 45 Deg.
Wavelength: 940nm.
Typical forward voltage drop: 1.1V.
Diameter: 5mm.
Reciever (Rx):
Power: 0.15W.
Maximum Current (Approx): 30mA.
Receiving Angle (Approx): 45 Deg.
Wavelength: 940nm.
Typical forward voltage drop: 1.2V.
Diameter: 5mm.
Kind regards,
Frank.
Not surprising these are just the raw IR LED and IR diode, you need an amplifier of some sorts. Even then the distance will be limited to a few inches.
This project shows you how to hook up such a system:-
http://www.thebox.myzen.co.uk/Hardware/Sneak_Thief.html
