Hello,
I've been working on a project for more than a week that reads an MP3 file from the SD card and outputs it to a speaker. The sound quality isn't that important, it's just supposed to be the whistle of a steam locomotive.
The module is an ESP32 CAM.
Only a limited number of pins are still free.
These are :
GPIO12, GPIO15, GPIO14, GPIO02, GPIO04.
I can use either a DAC I2S PCM5102 or a LM386 audio amplifier.
How do I have to add the code so that I can output the MP3 sound to a speaker?
Can someone please help me?
Many thanks in advance.
This is the code
Project: ESP32-CAM handle SD-Card
Author: Kurt Struevy
Date: Created 01.06.2023
Version: V1.0
IDE: Arduino IDE 2.1.0
Required Board (Tools -> Board -> Boards Manager...)
- Board: AI Thinker ESP32-CAM
#include "SD_MMC.h"
pinMode(4, OUTPUT);
// Mounten der SD-Karte
if(!SD_MMC.begin())
Serial.println("Kann die SD-Karte nicht mounten");
return;
uint8_t cardType = SD_MMC.cardType();
if(cardType == CARD_NONE)
Serial.println("Keine SD-Karte eingelegt");
return;
Serial.printf("Kartentyp = %d\n",cardType);
listDir(SD_MMC,"/",0);
void listDir(fs::FS &fs, const char * dirname, uint8_t levels)
Serial.printf("Listing directory: %s\n", dirname);
File root = fs.open(dirname);
if(!root)
Serial.println("Failed to open directory");
return;
if(!root.isDirectory())
Serial.println("Not a directory");
return;
File file = root.openNextFile();
while(file)
if(file.isDirectory()){
Serial.print(" DIR : ");
Serial.println(file.name());
if(levels)
listDir(fs, file.name(), levels -1);
Serial.print(" FILE: ");
Serial.print(file.name());
Serial.print(" SIZE: ");
Serial.println(file.size());
//nothing to do
And this is the output on the serial monitor:
Kartentyp = 3
Listing directory: /
DIR : System Volume Information
DIR : MP3
DIR : Pictures
FILE: LoveLetter.txt SIZE: 12
