Hello,
I am trying to read and write to a DS1086 silicon oscillator. I started with I2C scanner and added lines building up reading the registers then writing them.
There are 5 registers to read and 4 to write with then a final command to commit to the EEPROM.
Problem 1: I am unsure how I discard what ever the 3 MSBs are.
What I am finding tricky is recovering, for example, the 5 LSBs of a returned byte.
Eg, the "Range" 0x37 will return
MSB LSB
NA NA NA b4 b3 b2 b1 b0
And then I need to recover bits 4 to 0 and apply an offset before writing that new value back.
Problem 2: Writing MSBs to a register, possibly, not sure
After that, i need to write 2 registers for DAC values (0x08 DAC hi and 0X09 DAC low). The Hi i am able to get to work and read back correctly, but the low is not working.
Possibly the issue is the low register value needs to be justified towards the MSB;
MSB LSB
b1 b0 0 0 0 0 0 0
EG if my low needs to be 11000000, i would write C0 but it comes back as B1. Even if i write 0x00, i get B1 back.
Register Address Sending Reads Back
Prescaler 0x02 0xF3 0xF3
DAC Hi 0x08 0x4F 0x4F
DAC Lo 0x09 0xC0 / 00 0xB1 //writing anything reads back B1
Offset 0x0E 0xEB 0xEB
Addr 0x0D NA
Range 0x37 NA //example 0001 0010 but only interested in 1 00 10
Write EE 0x3F NA
For writing the DAC values, i tried first writing 2 registers one after the other, but found https://github.com/hvictor/DS1086/blob/main/ds1086_prog.ino and hvictor wrote these sequentially. Not sure the right thing to do.
My full code running on Mega 2560:
#include <Wire.h>
byte devAddr;
byte offsetDefault;
byte currentDAChi;
byte currentDAClo;
byte currentRange; //offset default
byte currentOffset;
byte currentPrescaler;
Wire.begin();
Serial.begin(9200);
delay(100);
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for (address = 1; address < 127; address++ ) {
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0) {
Serial.print("I2C device found at address 0x");
if (address < 16) {
Serial.print("0");
Serial.println(address, HEX);
devAddr = address;
nDevices++;
else if (error == 4) {
Serial.print("Unknow error at address 0x");
if (address < 16) {
Serial.print("0");
if (nDevices == 0) {
Serial.println("No I2C devices found\n");
else {
Serial.println("done\n");
Serial.println("");
Serial.println("###########################");
Serial.print("Reading device: ");
Serial.println(devAddr, HEX);
//DAChi
Wire.beginTransmission(devAddr);
Wire.write(0x08); // Point to register
Wire.endTransmission(false); // Do not release the line
Wire.requestFrom(devAddr, 1); // Request to read 1 byte. The address has the last bit set (READ bit).
currentDAChi = Wire.read();// & 0xFF;
//DAClo
Wire.write(0x09); // Point to register
currentDAClo = Wire.read();// & 0xC0;
//Range or default offset **READ ONLY**
Wire.write(0x37); // Point to register
currentRange = Wire.read();// & 0x1F;
//Offset
Wire.write(0x0E); // Point to register
currentOffset = Wire.read();// & 0x1F;
//Prescaller
Wire.write(0x02); // Point to register
currentPrescaler = Wire.read();// & 0x0F;
Serial.print("Current DAChi = ");
Serial.println(currentDAChi, HEX);
Serial.print("Current DAClo = ");
Serial.println(currentDAClo, HEX);
Serial.print("Current Range = ");
Serial.println(currentRange, HEX);
Serial.print("Current Offset = ");
Serial.println(currentOffset, HEX);
Serial.print("Current Prescaler = ");
Serial.println(currentPrescaler, HEX);
delay(2000);
//byte newOffset = currentRange - 2;
byte newOffset = 0xEB;
Serial.print("New Offset = ");
Serial.println(newOffset, HEX);
Serial.println("Writing EEPROM");
// PRESCALER register
// Store 0x03 in the
// Add 0xF[value] ie binary 1111[bbbb]
Wire.write(0x02); // PRESCALER address = 0x02
Wire.write(0xF3);
delay(10);
// OFFSET register
// Store Result of range 0x37 minus the table offset at the offset 0x0E register.
// Need to add leading 111[bbbbb]
Wire.beginTransmission(0x58);
Wire.write(0x0E); // OFFSET address = 0x0E
Wire.write(newOffset);
delay(10);
// DAC registers
// DAC High
Wire.write(0x08); // DAC address = 0x08
Wire.write(0x4F);
Wire.write(0xC0);
delay(10);
// DAC registers
// DAC Low
//Wire.beginTransmission(0x58);
//Wire.write(0x09);
//Wire.write(0xC0);
//Wire.endTransmission();
//delay(10);
// Write EEPROM
Wire.write(0x3F);
//DAChi
//DAClo
//Offset
//Prescaller
delay(2000);
while (1) {
digitalWrite(LED_BUILTIN, HIGH);
delay(20);
digitalWrite(LED_BUILTIN, LOW);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
Appreciate if anybody can help!
