Hi ALL,
I am using Atmega328pb to read and write on MCP3561R ADCs but I get nothing
Here it is my read function for example:
long Read_MCP_Reg(byte Address, byte Address_reg, byte Command)
byte IRQ_Status = 0;
long Reg_val = 0;
byte uC_2_MCP = ((Address & 0x03) << 6 )|((Address_reg & 0x0F) << 2)|(Command & 0x03);
digitalWrite(RTS,HIGH);
RS485.print(uC_2_MCP, BIN);//serial.print(78, BIN) gives "1001110"
digitalWrite(RTS,LOW);
digitalWrite(CS,LOW);
delay(1);
// ******* Start ******* //
// **** Send command form uC to MCP3561 and receive the Status byte **** //
for(int i = 0; i < 7; i++)
digitalWrite(SDI,bitRead(uC_2_MCP,7-i)); // Device Latches SDI on Rising Edge (page70)
delayMicroseconds(20);
digitalWrite(SCLK, HIGH);
IRQ_Status = (IRQ_Status << 1) + digitalRead(SDO); // Device Latches SDO on Falling Edge (page70)
digitalWrite(SCLK,LOW);
RS485.print(IRQ_Status, BIN);//serial.print(78, BIN) gives "1001110"
RS485_println("\n");
delay(1);
if(bitRead(IRQ_Status,4)!= bitRead(IRQ_Status,3))
// The command is verified
Verified_Cmd = true;
RS485_println("ACK_MCP+ \n");
if(bitRead(IRQ_Status,2))
Valid_ADC = true;
Valid_ADC = false;
RS485_println("ADC DATA is not available");
RS485_println("ACKMCPcmd--");
digitalWrite(CS,HIGH);
Valid_ADC = false;
Verified_Cmd = false;
if ((Address_reg == 0) || (Address_reg > 6 && Address_reg < 0xC))
for(int i = 0; i < 24; i++)
Reg_val = (Reg_val << 1) + digitalRead(SDO);
delayMicroseconds(50);
Reg_val = (Reg_val ); //& 0x00FFFFFF
RS485.print(Reg_val, HEX);//serial.print(78, BIN) gives "1001110"
delay(1);
return Reg_val;
else if((Address_reg > 0 && Address_reg < 7) || (Address_reg == 0xD)|| (Address_reg == 0xC))
Reg_val = (Reg_val );// & 0x000000FF
delay(1);
return Reg_val;
else if ((Address_reg == 0xE) || (Address_reg == 0xF))
for(int i = 0; i < 16; i++)
Reg_val = (Reg_val);// & 0x0000FFFF
delay(1);
return Reg_val;
RS485_println("Wrong Address to MCP");
return 0;
Thanks and regards
