Reading array of bytes from PROGMEM
Hi!
I'm trying to write a simple program (as a pre-cursor to a more complicated one) that stores an array of bytes to progmem, and then reads and prints the array. I've looked through a million blog/forums posts online and think I'm doing everything fine, but I'm still getting utter gibberish as output.
Here is my code, any help would be much appreciated!
#include <avr/pgmspace.h>
  byte hello[10] PROGMEM = {1,2,3,4,5,6,7,8,9,10};
  byte buffer[10];
  memcpy_P(buffer, (char*)pgm_read_byte(&hello), 10);
  for(int i=0;i<10;i++){
   //buffer[i] = pgm_read_byte(&(hello[i])); //output is wrong even if i use this
   Serial.println(buffer[i]);
The output I get is
148
93
0
12
148
93
0
12
148
93
if i use memcpy, and
49
5
9
240
108
192
138
173
155
173
if i use the buffer = .... statement in the for loop.
const byte hello[10] PROGMEM
You need to create the array outside of setup() then it will work. The syntax can be simplified as follows:
const byte hello[10] PROGMEM = {1,2,3,4,5,6,7,8,9,10};
  byte buffer[10];
  memcpy_P(buffer, hello, 10);
   //buffer[i] = pgm_read_byte(&hello[i]); //output is also OK
