So I've been looking a little bit and I don't know what to look for.
But if you connected a headphone jack to an analog input(or 2 for stereo), would it be fairly easy to read signal and then make leds flash with the music. If there is a article or project about this already, a link would be great.
To make the input biased at 2.5V so the audio signal can swing both above and below this point. It is like putting a DC offset onto the input. That is why the potential divider is there at the other side of the capacitor. The capacitor also blocks this DC from getting into the audio output stage of your amplifier. (not good).
An audio signal will swing positive and negative, an Arduino can only measure positive signals. The DC off set is to allow these two systems to work together. Your audio output should be set to +/- 2.5v to get the full output range from the arduino.
With no signal you will see a value of 512 read from the analogue input. As the audio volume increases the readings will peak at a higher and lower value to this. At the maximum volume you get readings of 0 and 1023.
The audio side should be measured as a AC voltage on the audio device's side of the coupling capacitor. With a steady sine wave tone you should set the amplitude volume at 1.77 vac rms. That should keep any audio signal within the Arduino 0-5vdc range if using the 2.5vdc offset. Don't forget that the device and Arduino need to have their grounds wired together.
Making very heavy weather of a capacitor and voltage divider.
Base is 2.5 so a +2.5 would actually be 5v and a -2.5 would be 0 v?
Yes but don't worry you are not going to get an absolute reading anyway, just a number between 0 and 1023.
So an instantaneous audio voltage of +2.5 would present 5V to the arduino (2.5 audio + 2.5 DC offset).
Likewise an instantaneous audio voltage of -2.5 would present 0V to the arduino (-2.5 audio + 2.5 DC offset).
Once you get it wired in, it might be more clear to you if you then in your software map the signals range of 0-1023 to -2.5 to +2.5. Or to -100 to +100 and treat it as a percentage of signal.
It's only a dot when the wires cross, not when there is a T junction. There are no crossing wires in the audio out section.
In fact some people say it is bad practice to have crossing wires that join and that all joins should be done with T sections, but it is not universally adhered to.
Ok I figured it out. I was using a circuit simulator and it didn't the voltage just stayed at -2.5 and +2.5 but I didn't wait long enough for the cap to charge. Makes more sense now, the offset just adds it's voltage to the ac voltage correct?
