Hello,
I have a simple sketch that uses the ArduinoBLE.h library. I have set up one ESP32 referred to as ESP32Sender to act as the device sending data and this appears to be working okay. I have set up two items of changing data as notify items on ESP32Sender. I can see it is sending out data as I can connect t it with my smartphone using the BLE Scanner app and see incoming data updating automatically. Please see screenshot.
I want to receive this data on another ESP32 referred to as ESP32Receiver. I can connect successfully to the ESP32Sender from ESP2Receiver. This is confirmed on the ESP32Sender both in serial monitor and the onboard led flashing as it sends out data.
What I cannot seem to manage is receive the data being sent out by ESP32Sender. I have tried for many hours to try and make this work but seem to be going round in circles.
I would be grateful if anybody could suggest a snippet of code that would allow me to receive the incoming data on ESP32Receiver. I just need to Serial.print it for now. I have marked a section in ESP32Receiver with //THIS IS WHERE UPDATED DATA IS RECEIVED as a place where the incoming data could go.
Code for both units is below and a screenshot from my smartphone is attached.
All help is greatly appreciated
Chazza
ESP32Sender code
#include <ArduinoBLE.h>
BLEService echoService("00000000-0000-1000-8000-00805f9b34fb");
BLEStringCharacteristic charac("741c12b9-e13c-4992-8a5e-fce46dec0bff", BLENotify, 40);
BLEStringCharacteristic cnt("741c12b9-e13c-4992-8a5e-fce46dec0bfe", BLENotify, 40);
BLEDescriptor Descriptor("beca6057-955c-4f8a-e1e3-56a1633f04b1", "Descriptor");
String var = "";
String animal[10] = { "cat", "dog", "bird", "mouse", "fox", "elephant", "lion", "tiger", "monkey", "giraffe" };
unsigned long previousMillis = 0;
const long interval = 500; // interval
int count = 0;
int led = 2;
while (!Serial)
if (!BLE.begin()) {
Serial.println("starting BLE failed.");
while (1)
BLE.setLocalName("ESP32Sender");
BLE.setAdvertisedService(echoService);
charac.addDescriptor(Descriptor);
echoService.addCharacteristic(charac);
echoService.addCharacteristic(cnt);
BLE.addService(echoService);
BLE.advertise();
Serial.println("Bluetooth device active, waiting for connections...");
Serial.println(" ");
pinMode(led, OUTPUT);
BLEDevice central = BLE.central();
if (central) {
Serial.println("* Connected to central device!");
Serial.print("Connected to central : ");
Serial.println(central.address());
while (central.connected()) {
if (currentMillis - previousMillis >= interval) {
digitalWrite(led, (!digitalRead(led)));
charac.writeValue(animal[count]); // name of animal from array
cnt.writeValue(String(count)); // index of animal from array
Serial.print(animal[count]);
Serial.print(", ");
count = count + 1;
if (count == 10) {
count = 0;
delay(50);
Serial.print("Disconnected from central: ");
ESP32Receiver Code
while (!Serial);
// begin initialization
if (!BLE.begin()) { // Initializes the BLE Device
Serial.println("starting BLE failed!");
while (1);
Serial.println("BLE Central - Peripheral Explorer");
// start scanning for peripherals that are advertising, returns true on success
BLE.scan();
// check if a peripheral has been discovered
BLEDevice peripheral = BLE.available(); //BLEDevice object named peripherical created. Query for a discovered BLE device that was found during the scan
if (peripheral) {
// discovered a peripheral, print out address, local name, and advertised service
Serial.print("Found ");
Serial.print(peripheral.address());
Serial.print(" '");
Serial.print(peripheral.localName());
Serial.print("' ");
Serial.print(peripheral.advertisedServiceUuid());
// see if peripheral is a POD-2B_SN2981
if (peripheral.localName() == "ESP32Sender") {
// stop scanning
BLE.stopScan();
// we call this to get all the parameters from the peripheral
explorerPeripheral(peripheral);
// peripheral disconnected, we are done
while (1) {
// do nothing
//initial connection to peripheral object
void explorerPeripheral(BLEDevice peripheral) {
// connect to the peripheral
Serial.println("Connecting ...");
if (peripheral.connect()) {
Serial.println("Connected");
else {
Serial.println("Failed to connect!");
return;
// discover peripheral attributes
Serial.println("Discovering attributes ...");
//discover attributes is a percurosr that is needed before servicecount I guess?
if (peripheral.discoverAttributes()) {
Serial.println("Attributes discovered");
else {
Serial.println("Attribute discovery failed!");
peripheral.disconnect();
return;
int serviceCount = peripheral.serviceCount();
Serial.print(serviceCount);
Serial.println(" services discovered");
BLEService tempService = peripheral.service("00000000-0000-1000-8000-00805f9b34fb");
if (!tempService) {
Serial.println("Service not found!");
// peripheral.disconnect();
else {
Serial.println("Service found!");
exploreService(tempService);
void exploreService(BLEService service) {
Serial.println("Exploring Service");
BLECharacteristic simpleKeyCharacteristic = service.characteristic("741c12b9-e13c-4992-8a5e-fce46dec0bff");
Serial.println("Subscribing to simple key characteristic ...");
if (!simpleKeyCharacteristic) {
Serial.println("no simple key characteristic found!");
return;
else if (!simpleKeyCharacteristic.canSubscribe()) {
Serial.println("simple key characteristic is not subscribable!");
return;
else if (!simpleKeyCharacteristic.subscribe()) {
Serial.println("subscription failed!");
return;
else {
Serial.println("Subscribed!");
while(-1) {
//check if value has been updated
if (simpleKeyCharacteristic.valueUpdated()) {
