Reading Bourns bps120 differential pressure sensor to get airspeed
After the usual fussing, I seem to have made Robert Rau’s MS4525 code work. See my code at bottom.
I do not understand what what these functions do:
const int16_t MS4525FullScaleRange = 1; // 1 psi
const int16_t MS4525MinScaleCounts = 1638;
const int16_t MS4525FullScaleCounts = 14746;
const int16_t MS4525Span=MS4525FullScaleCounts-MS4525MinScaleCounts;
const int16_t MS4525ZeroCounts=(MS4525MinScaleCounts+MS4525FullScaleCounts)/2;
It seems to me that this device emits a 14 bit sequence which decodes to a PSI measurement.
It is a 1 psi sensor so that it obvious
The Bourns BPS 120 data sheet shows only a MAX of 16384 which I assume is the Bourn version of the 14746 shown in the code, but if they don’t show the MinScaleCounts what should I use?
I have another calibrated airspeed sensor so I can fly this one with the other and see how close it is. Ground testing suggests it might be pretty close.
I would be delighted if someone detects something stupid in here and let’s me know.
 * much modfied sensor reader  6/13/2020 jaf
#include <Wire.h>      // Arduino I2C library
#include <stdint.h>    // Standard C, Allows explicit data type declaration.
const uint8_t MS4525DAddress = 0x28;
//  fetch_pressure is a function to do the I2C read and extraction of the three data fields
byte fetch_pressure(uint16_t &P_dat)
 byte _status;
 byte Press_H;
 byte Press_L;
 Wire.requestFrom(MS4525DAddress, static_cast<uint8_t>(2), static_cast<uint8_t>(true));  //Request 2 bytes, 2 pressure/status
 Press_H = Wire.read();
 Press_L = Wire.read();
 _status = (Press_H >> 6) & 0x03;
 Press_H = Press_H & 0x3f;
 P_dat = (((uint16_t)Press_H) << 8) | Press_L;
  return _status;
//  setup is the main function to setup the diagnostic serial port and the I2C port
 Wire.begin();
 // wait until serial port opens for native USB devices
 while (! Serial)
   delay(1);
 Serial.println("MS4525DO test");
 byte _status;    // A two bit field indicating the status of the I2C read
 uint16_t P_dat;  // 14 bit pressure data
 float psi;
 float mps;
 float mph;
   _status = fetch_pressure(P_dat);
   switch (_status)
     case 0:
       //Serial.println("Ok ");
     case 1:
       Serial.println("Busy");
     case 2:
       Serial.println("Slate");
     default:
       Serial.println("Error");
   psi=(static_cast<float>(static_cast<int16_t>(P_dat)-MS4525ZeroCounts))/static_cast<float>(MS4525Span)*static_cast<float>(MS4525FullScaleRange);
   Serial.print("psi:");
   Serial.println(psi);
   mps=sqrt(2*(psi*6894.76)/1.225);
   mph=mps*2.23694;
   Serial.print("mph: ");
   Serial.println(mph);
Never mind. I read Honeywell's excellent guide on I2C and their pressure sensors which emit data which must be transformed via a transfer function to reveal PSI pressure in my case.
Bourns publishes their transfer function in the device data, and all I need to do is use their funtiobn rather than Honeywell's or the MS4525 funtion on which my code was based.
Yippee.
