So I have the proposed sloution working in a separate program
/* Portenta - FileRead
The sketch shows how to mount an usb storage device and how to
read from an existing file.
to use this sketch create a .txt file named Arduino.txt,
in your storage device and write some content inside.
The circuit:
- Portenta H7
This example code is in the public domain.
#include <Arduino_USBHostMbed5.h>
#include <DigitalOut.h>
#include <FATFileSystem.h>
//#include <string>
USBHostMSD msd;
mbed::FATFileSystem usb("usb");
// If you are using a Portenta Machine Control uncomment the following line
mbed::DigitalOut otg(PB_14, 0);
struct cal_val {
const char* identifier;
double value;
cal_val calibrations[] = {
{"Aa2", 0},
{"Aa1", 0},
{"Aa0", 0},
{"Ba2", 0},
{"Ba1", 0},
{"Ba0", 0},
{"Ca2", 0},
{"Ca1", 0},
{"Ca0", 0},
while (!Serial);
delay(2500);
Serial.println("Starting USB File Read example...");
// if you are using a Max Carrier uncomment the following line
//start_hub();
while (!msd.connect()) {
Serial.println("Mounting USB device...");
int err = usb.mount(&msd);
if (err) {
Serial.print("Error mounting USB device ");
Serial.println(err);
while (1);
Serial.print("read done ");
mbed::fs_file_t file;
struct dirent *ent;
int dirIndex = 0;
int res = 0;
Serial.println("Open file..");
FILE* f = fopen("/usb/config.txt", "r+");
char buf[256];
Serial.println("File content:");
int i=0;
double Cal[10];
while (fgets(buf, sizeof(buf), f) != NULL) {
char *identifier = strtok(buf, "=");
if (identifier != nullptr) {
char *value = strtok(NULL, "="); // Get the second token
if (value != nullptr) {
for (byte calibrationIndex = 0; calibrationIndex < (sizeof(calibrations) / sizeof(calibrations[0])); calibrationIndex++) {
if (strcmp(identifier, calibrations[calibrationIndex].identifier) == 0) {
calibrations[calibrationIndex].value = strtod(value, nullptr);
Serial.println("Failed to parse line");
i++;
Serial.println(get_cal_val("Aa1"),10);
Serial.println("File closing");
fflush(stdout);
err = fclose(f);
if (err < 0) {
Serial.print("fclose error:");
Serial.print(strerror(errno));
Serial.print(" (");
Serial.print(-errno);
Serial.print(")");
Serial.println("File closed");
// handle disconnection and reconnection
if (!msd.connected()) {
msd.connect();
double get_cal_val(const char* id) {
if (strcmp(id, calibrations[calibrationIndex].identifier) == 0) {
return calibrations[calibrationIndex].value;
// If the identifier is not found, return a default value (you can choose an appropriate value)
return -1;
I have been trying to now move that into the main program I have been writing shown here:
Written By: Nick Mckenna
Date Last Modified: 2024-07-08
Purpose: This code is designed to read the input from 3 flexi force A401 sensors and display them on an arduino giga.
In additionaly to displaying the output the software can also log and save the messured data. well it will be able to eventually.
#include "Arduino.h"
//Librarys Included Required to make the Giga R1 Display function:
// Arduino Mbed OS giga Boards// installed in the board manager
//just look for arduino giga display libary and install all depents, then go and manually set lvgl version
#include "Arduino_H7_Video.h"//https://github.com/arduino/ArduinoCore-mbed/tree/main/libraries/Arduino_H7_Video
#include "lvgl.h" //version: 8.3.11//https://github.com/lvgl/lvgl //powes the graphics and GUI
#include "Arduino_GigaDisplayTouch.h"//https://www.arduino.cc/reference/en/libraries/arduino_gigadisplaytouch/
#include "lv_conf.h"
//C:\Users\NM27Eng\AppData\Local\Arduino15\packages\arduino\hardware\mbed_giga\4.1.1\libraries\Arduino_H7_Video\src\lv_conf.h
//is the location to change config stuff for the program. havent been able to get it to use the one in lib folder
//Librarys Required to make the on board RTC function
#include "mbed.h"
#include <mbed_mktime.h>
//Library needed to enable comunication with the usb thumb drive
#include <PluggableUSBHID.h>
//#include <USBHID_Types.h>
#include <USBKeyboard.h>
#include <USBMouse.h>
#include <USBMouseKeyboard.h>
//#include "lv_conf.h" //includes the lv_conf.h file into sketch
//"" means sketch will look in sketch folder first.
hardware info:
Arduino Pin -> Breakout Pin
A0 -> input from sensor 1
A1 -> Input from Sensor 2
A2 -> Input grom Sensor 3
int flexiAin=A0, flexiBin=A1, flexiCin=A2;//pins for input from each sensor
int polrate = 1000;//number of milliseconds between each sensor poll/log
//Linear Scaleing Values to convert the sensor inputs into pounds
// Variables are in the Form of lbf=mx+B, where the Ms and Bs are denoted by A,B,or C
double Aa2=0,Aa1=1, Aa0=0;
double Ba2=0, Ba1=1, Ba0=0;
double Ca2=0, Ca1=1, Ca0=0;
double Cal[10];//array for calibration values
//Specifying height and width of display
Arduino_H7_Video Display(800, 480, GigaDisplayShield);
Arduino_GigaDisplayTouch TouchDetector;//needed to enable touch for display.
//bool RTC_page_visible = false;
//global variables
lv_obj_t * RTC_time;//text on RTC portion
lv_obj_t * LOAD;// pointer for total load of fixture
lv_obj_t * SA;//pointer for sensor A
lv_obj_t * SB;// pointer for sensor B
lv_obj_t * SC;// pointer for sensor C
lv_obj_t * ELPTIME;// pointer for total elapsed time
lv_obj_t * menu;// Pointer for current menu
lv_obj_t * RTC_page;
lv_obj_t * ELPTIME_btn;//
lv_timer_t * Sensor_Read;
lv_obj_t * I_A_LABEL;
lv_obj_t * I_B_LABEL;
lv_obj_t * I_C_LABEL;
lv_obj_t * I_A;
lv_obj_t * I_B;
lv_obj_t * I_C;
lv_obj_t * USB_btn;
lv_obj_t * USB_btn_label;
static lv_style_t logbtn_pr;
static lv_style_t logbtn;
static lv_style_t logbtn_no_drive;
static lv_style_t S_A;
static lv_style_t S_B;
static lv_style_t S_C;
char drive_name[11]="B_DATA_LOG";
USBHostMSD msd;
mbed::FATFileSystem usb(drive_name);
struct dirent *ent;
int err;//for if usb throws error
FILE* f;
bool datalog = 0;
bool msdcon = false;//true when msd has been connected false when msd has not been connected.
unsigned int ELPTIME_timer;
unsigned int ELPTIME_start;
unsigned int ELPTIME_cnt;
char Char_RTC_time[32];
char RTC_Date[17];
//data structure for importing values from usb drive
struct cal_val {
double value;
{"Aa2", 0},
{"Aa1", 0},
{"Aa0", 0},
{"Ba2", 0},
{"Ba1", 0},
{"Ba0", 0},
{"Ca2", 0},
{"Ca1", 0},
{"Ca0", 0},
Display.begin();// Initlizes display
TouchDetector.begin();//Initalizes Touch interface
Serial.begin(9600);// Initalizes Serial Monitor
analogReadResolution(12);//enables the analog to digital converter to do #bit numbers
Serial.println("setup");
static lv_style_t style;
lv_style_init (&style);
lv_style_set_text_font(&style, &lv_font_montserrat_28);
lv_style_set_text_color(&style, lv_color_make(0, 0, 0));
static lv_style_t lstyle;
lv_style_init (&lstyle);
lv_style_set_text_font(&lstyle, &lv_font_montserrat_48);
lv_style_set_text_color(&lstyle, lv_color_make(0, 0, 0));
//static lv_style_t logbtn_pr;
lv_style_init (&logbtn_pr);
lv_style_set_outline_width(&logbtn_pr,30);
lv_style_set_bg_color(&logbtn_pr, lv_palette_main(LV_PALETTE_RED));
//static lv_style_t logbtn;
lv_style_init (&logbtn);
lv_style_set_outline_width(&logbtn,0);
lv_style_set_bg_color(&logbtn, lv_palette_main(LV_PALETTE_GREEN));
//static lv_style_t logbth_no_drive
int radius = 250;
// lv_style_t S_A
lv_style_init (&S_A);
lv_style_set_radius(&S_A, radius);
lv_style_set_text_font(&S_A, &lv_font_montserrat_28);
lv_style_set_bg_color(&S_A, lv_color_make(0, 255, 0));
lv_style_set_text_color(&S_A, lv_color_make(0, 0, 0));
//Style for S_B, button circle indication
lv_style_init(&S_B);
lv_style_set_radius(&S_B,radius);
lv_style_set_text_font(&S_B, &lv_font_montserrat_28);
lv_style_set_bg_color(&S_B, lv_color_make(0, 255, 0));
lv_style_set_text_color(&S_B, lv_color_make(0, 0, 0));
//style for S_C, Button circle indication
lv_style_init(&S_C);
lv_style_set_radius(&S_C, radius);
lv_style_set_text_font(&S_C, &lv_font_montserrat_28);
lv_style_set_bg_color(&S_C, lv_color_make(0, 255, 0));
lv_style_set_text_color(&S_C, lv_color_make(0, 0, 0));
//Initilizes the pins required for the USB-A port
pinMode(PA_15, OUTPUT); //enable the USB-A port
digitalWrite(PA_15, HIGH);//Powers the usb port
//usb_connect();
//defines the partent "main page" and acoscated stuff
menu = lv_menu_create(lv_scr_act());
lv_obj_set_size(menu,Display.width(), Display.height());
lv_obj_center(menu);
lv_obj_t * cont;
//RTC page
RTC_page = lv_menu_page_create(menu, NULL);
cont = lv_label_create(RTC_page);
lv_obj_set_size(RTC_page,Display.width(), Display.height());
lv_obj_center(RTC_page);
lv_obj_clear_flag(RTC_page, LV_OBJ_FLAG_SCROLLABLE);//removes ability to scroll button in grid
lv_obj_t * SET_YEAR = lv_textarea_create(RTC_page);
lv_obj_align(SET_YEAR, LV_ALIGN_TOP_MID, -100, -100);
lv_obj_set_size(SET_YEAR, 200,105);
lv_textarea_set_placeholder_text(SET_YEAR, "YYYY");
//lv_obj_center(SET_YEAR);
//lv_obj_add_event_cb(RTC_btn, btn_event_cb, LV_EVENT_CLICKED, NULL);
lv_textarea_set_one_line(SET_YEAR, true);
// main menu
lv_obj_t * main_page = lv_menu_page_create(menu, NULL);
lv_obj_clear_flag(main_page, LV_OBJ_FLAG_SCROLLABLE);//removes ability to scroll button in the object "main menu"
static lv_coord_t col_dsc[] = { 370, 115 ,115, 115, LV_GRID_TEMPLATE_LAST };//sets size and number of colombs on main page
static lv_coord_t row_dsc[] = { 105, 105, 105, 105, LV_GRID_TEMPLATE_LAST };//sets size and number of rows on main page
lv_obj_t* grid = lv_obj_create(main_page);
lv_obj_set_grid_dsc_array(grid, col_dsc, row_dsc);
lv_obj_set_size(grid, Display.width(), Display.height());
lv_obj_clear_flag(grid, LV_OBJ_FLAG_SCROLLABLE);//removes ability to scroll button in the object "main menu"
//top left
lv_obj_t* obj;
obj = lv_obj_create(grid);
lv_obj_set_grid_cell(obj, LV_GRID_ALIGN_STRETCH, 0, 1, //column
LV_GRID_ALIGN_STRETCH, 0, 3); //row
lv_obj_clear_flag(obj, LV_OBJ_FLAG_SCROLLABLE);//removes ability to scroll button in grid
I_A = lv_btn_create(obj);
lv_obj_add_style(I_A, &S_A, 0);
lv_obj_set_size(I_A, 125,125);
lv_obj_align(I_A, LV_ALIGN_CENTER, 0, -80);
I_A_LABEL = lv_label_create(I_A);
lv_obj_center(I_A_LABEL);
lv_label_set_text(I_A_LABEL, "A\n66666");
lv_obj_set_style_text_align(I_A_LABEL, LV_TEXT_ALIGN_CENTER, 0);//Sets the text of the label to center aligned
I_B = lv_btn_create(obj);
lv_obj_add_style(I_B, &S_B, 0);
lv_obj_set_size(I_B, 125,125);
lv_obj_align(I_B, LV_ALIGN_CENTER, 80, 80);
I_B_LABEL = lv_label_create(I_B);
lv_obj_center(I_B_LABEL);
lv_obj_set_style_text_align(I_B_LABEL, LV_TEXT_ALIGN_CENTER, 0);//Sets the text of the label to center aligned
I_C = lv_btn_create(obj);
lv_obj_add_style(I_C, &S_C, 0);
lv_obj_set_size(I_C, 125,125);
lv_obj_align(I_C, LV_ALIGN_CENTER, -80, 80);
I_C_LABEL = lv_label_create(I_C);
lv_obj_center(I_C_LABEL);
lv_obj_set_style_text_align(I_C_LABEL, LV_TEXT_ALIGN_CENTER, 0);//Sets the text of the label to center aligned
//bottom left-RTC_time
LV_GRID_ALIGN_STRETCH, 3, 1); //row
//Button
//lv_obj_t * RTC_time;
lv_obj_t * RTC_btn = lv_btn_create(obj);
lv_obj_set_size(RTC_btn, 370,105);
lv_obj_center(RTC_btn);
lv_menu_set_load_page_event(menu, RTC_btn, RTC_page);
lv_timer_t * timer = lv_timer_create(get_rtc, 1000, NULL);
lv_timer_ready(timer);
RTC_time = lv_label_create(RTC_btn);
lv_label_set_text(RTC_time, "0000-00-00 00:00:00");//sets text to somthing before the RTC kicks in with the actual value
lv_obj_add_style(RTC_time, &style, 0);
lv_obj_center(RTC_time);
//top right-main load value
//format for grid cells is (begining quadrant, amout to stretch cell)
lv_obj_set_grid_cell(obj, LV_GRID_ALIGN_STRETCH, 1, 3, //column
LV_GRID_ALIGN_STRETCH, 0, 2); //row
lv_obj_t * LOAD_btn = lv_btn_create(obj);
LOAD = lv_label_create(LOAD_btn);
lv_obj_set_size(LOAD_btn, 370,220);
lv_obj_center(LOAD_btn);
lv_obj_add_event_cb(LOAD_btn, btn_event_cb, LV_EVENT_CLICKED, NULL);
lv_label_set_text(LOAD, "000"); //sets text to somthing before the RTC kicks in with the actual value
lv_obj_add_style(LOAD, &lstyle, 0);
lv_obj_center(LOAD);
/*lv_timer_t */ Sensor_Read = lv_timer_create(S_Read, polrate, NULL);
lv_timer_ready(Sensor_Read);
// right side, 3 individual sensor inputs,
//Sensor 1
lv_obj_set_grid_cell(obj, LV_GRID_ALIGN_STRETCH, 1, 1, //column
LV_GRID_ALIGN_STRETCH, 2, 1); //row
// static lv_style_t style;
//lv_style_init (&style);
//lv_style_set_text_font(&style, &lv_font_montserrat_28);// Dont need this since font size was set above?
lv_obj_t * SA_btn = lv_btn_create(obj);
SA = lv_label_create(SA_btn);
lv_obj_set_size(SA_btn, 115,105);
lv_obj_center(SA_btn);
lv_obj_set_style_text_align(SA, LV_TEXT_ALIGN_CENTER, 0);//Sets the text of the label to center aligned
lv_obj_add_event_cb(SA_btn, btn_event_cb, LV_EVENT_CLICKED, NULL);
lv_label_set_text(SA, "000"); //sets text to somthing before the RTC kicks in with the actual value
lv_obj_add_style(SA, &style, 0);
lv_obj_center(SA);
//sensor 2
lv_obj_set_grid_cell(obj, LV_GRID_ALIGN_STRETCH, 2, 1, //column
lv_obj_t * SB_btn = lv_btn_create(obj);
SB = lv_label_create(SB_btn);
lv_obj_set_style_text_align(SB, LV_TEXT_ALIGN_CENTER, 0);//Sets the text of the label to center aligned
lv_obj_set_size(SB_btn, 115,105);
lv_obj_center(SB_btn);
lv_obj_add_event_cb(SB_btn, btn_event_cb, LV_EVENT_CLICKED, NULL);
lv_label_set_text(SB, "000"); //sets text to somthing before the RTC kicks in with the actual value
lv_obj_add_style(SB, &style, 0);
lv_obj_center(SB);
//Sensor 3
lv_obj_set_grid_cell(obj, LV_GRID_ALIGN_STRETCH, 3, 1, //column
lv_obj_t * SC_btn = lv_btn_create(obj);
SC = lv_label_create(SC_btn);
lv_obj_set_style_text_align(SC, LV_TEXT_ALIGN_CENTER, 0);//Sets the text of the label to center aligned
lv_obj_set_size(SC_btn, 115,105);
lv_obj_center(SC_btn);
lv_obj_add_event_cb(SC_btn, btn_event_cb, LV_EVENT_CLICKED, NULL);
lv_label_set_text(SC, "000"); //sets text to somthing before the RTC kicks in with the actual value
lv_obj_add_style(SC, &style, 0);
lv_obj_center(SC);
// usb drive installed
USB_btn = lv_btn_create(obj);
USB_btn_label = lv_label_create(USB_btn);
lv_obj_add_style(USB_btn, &logbtn, 0);
lv_obj_set_size(USB_btn, 115,105);
lv_obj_center(USB_btn);
lv_obj_add_event_cb(USB_btn, USBbtn_event_cb, LV_EVENT_CLICKED, NULL);
//lv_obj_add
//lv_obj_add_style(ELPTIME, &style, 0);
//lv_obj_add_style(ELPTIME_btn,&btn_pr, LV_STATE_PRESSED);
lv_label_set_text(USB_btn_label, LV_SYMBOL_USB LV_SYMBOL_REFRESH); //sets text to somthing before the RTC kicks in with the actual value
lv_obj_add_style(USB_btn_label,&style, 0);
lv_obj_center(USB_btn_label);
//bottom right, start and stop data collection
lv_obj_set_grid_cell(obj, LV_GRID_ALIGN_STRETCH, 2, 2, //column
ELPTIME_btn = lv_btn_create(obj);
ELPTIME = lv_label_create(ELPTIME_btn);
lv_obj_add_style(ELPTIME_btn, &logbtn, 0);
lv_obj_set_size(ELPTIME_btn, 370,105);
lv_obj_center(ELPTIME_btn);
//lv_obj_add_flag(ELPTIME_btn, LV_OBJ_FLAG_CHECKABLE);
lv_obj_add_event_cb(ELPTIME_btn, btn_envent_cb, LV_EVENT_CLICKED, NULL);
//lv_obj_add
lv_label_set_text(ELPTIME, "start"); //sets text to somthing before the RTC kicks in with the actual value
lv_obj_center(ELPTIME);
lv_menu_set_page(menu, main_page);
lv_timer_handler();//continuously updates the display and GUI.
// Call back function that is called when button is clicked.
static void btn_event_cb(lv_event_t * e) //keeping this here for refrence right now but no longer needed largly
Serial.println("boop");
//lv_menu_set_page(menu, RTC_page);
static void btn_envent_cb(lv_event_t * ELPTIME_btn)
lv_obj_t * ob = lv_event_get_target(ELPTIME_btn);
char filename[40];
if(msd.connect()==true){
if(datalog == 0){
//mbed::fs_file_t file;
//lv_style_init (&logbtn_pr);
lv_obj_add_style(ob, &logbtn_pr, 0);
datalog=1;
snprintf(filename,40,"%s/Sensor_log_%s.txt",drive_name, RTC_Date);
Serial.println(filename);
lv_label_set_text(ELPTIME, "0:00:00");
f = fopen(filename,"w+");
lv_timer_ready(Sensor_Read);//imeditely calls function S_Read and bypasses poll rate of the S_Read function
} else{
//lv_style_init (&logbtn);
lv_obj_add_style(ob, &logbtn, 0);
datalog = 0;
fclose(f);
ELPTIME_timer=0;
ELPTIME_start=0;
ELPTIME_cnt=0;
}else{
//datalog != datalog;//toggles the log variable to indicate if the button was pressed or not
// gets the current time from the RTC module and then displays it on the RTC_time, label
static void get_rtc(lv_timer_t * timer) {
tm t;
_rtc_localtime(time(NULL), &t, RTC_4_YEAR_LEAP_YEAR_SUPPORT);
strftime(Char_RTC_time, 32, "%Y-%m-%d %k:%M:%S", &t);
lv_label_set_text(RTC_time, Char_RTC_time);
strftime(RTC_Date, 17, "%Y-%m-%d %k-%M", &t);
//return String(buffer);
void S_Read(lv_timer_t * Sensor_Read)
//reads the value of sensors A,B, and C
int A, Alb, B, Blb, C, Clb, total, diffA, diffB, diffC;
float avg;
float perdiffA,perdiffB, perdiffC;
tm t;
A = analogRead(flexiAin);
B = analogRead(flexiBin);
C = analogRead(flexiCin);
Alb = ((Aa2*(A^2))+(Aa1*A)+Aa0);
Blb = ((Ba2*(B^2))+(Ba1*B)+Ba0);
Clb = ((Ca2*(C^2))+(Ca1*C)+Ca0);
total = (Alb+Blb+Clb);//calcultes the total force being mesured
//Serial.println(total);
avg=((A+B+C)/3);
diffA = int((abs(A-avg)/avg)*255);
diffB = int((abs(B-avg)/avg)*255);
diffC = int((abs(C-avg)/avg)*255);
perdiffA = (((A-avg)/avg)*100);
perdiffB = ((B-avg)/avg)*100;
perdiffC = ((C-avg)/avg)*100;
// Convert integer values to strings
char As[12], Bs[12], Cs[12], Ts[10], buffer[40];
snprintf(As, 10, "A\n%d", Alb);
snprintf(Bs, 10, "B\n%d", Blb);
snprintf(Cs, 10, "C\n%d", Clb);
snprintf(Ts, 10, "%d lb",total);
//Color of S_A indcator
lv_style_set_bg_color(&S_A, lv_color_make(2*diffA, 255-2*diffA, 0));//sets the color of S_A based on how far off A is from average
lv_obj_invalidate(I_A);// tells lvgl that the style asocated with I_A has changed and that it needs to be reloaded.
lv_style_set_bg_color(&S_B, lv_color_make(2*diffB, 255-2*diffB, 0));//sets the color of S_A based on how far off A is from average
lv_obj_invalidate(I_B);// tells lvgl that the style asocated with I_A has changed and that it needs to be reloaded.
lv_style_set_bg_color(&S_C, lv_color_make(2*diffC, 255-2*diffC, 0));//sets the color of S_A based on how far off A is from average
lv_obj_invalidate(I_C);// tells lvgl that the style asocated with I_A has changed and that it needs to be reloaded.
// Update labels with the string representations of the integer values
lv_label_set_text_fmt(I_A_LABEL,"A\n%.2f%%", perdiffA);
lv_label_set_text_fmt(I_B_LABEL,"B\n%.2f%%", perdiffB);
lv_label_set_text_fmt(I_C_LABEL,"C\n%.2f%%", perdiffC);
lv_label_set_text(SA, As);
lv_label_set_text(SB, Bs);
lv_label_set_text(SC, Cs);
lv_label_set_text(LOAD, Ts);
//Serial.println("%c, %c, %c",As, Bs,Cs );
//Serial.println(Bs);
//Serial.println(Cs);
if(datalog==0 && ELPTIME_cnt==0){
}else if(datalog==1 && ELPTIME_cnt==0){
ELPTIME_start= time(NULL);
snprintf(buffer,50,"Time,Elapsed Time,A,B,C,Total");
Serial.println(buffer);
fprintf(f,"%s\n",buffer);
snprintf(buffer,50,"%s,%d,%d,%d,%d,%d\r",Char_RTC_time,ELPTIME_cnt,Alb,Blb,Clb,total);
ELPTIME_cnt++;
fflush(stdout);
}else if(datalog==1 && ELPTIME_cnt>0){
fflush(stdout);
ELPTIME_cnt++;
_rtc_localtime((time(NULL)-ELPTIME_start), &t, RTC_4_YEAR_LEAP_YEAR_SUPPORT);
strftime(buffer, 16, "%k:%M:%S",&t);
lv_label_set_text(ELPTIME, buffer);
}else{
//usb_connect();
// my atempt at making a function to do make the boxes, seemed easir to just copy and paste
/*void make_btn(lv_obj_t * obj, lv_obj_t * label,lv_obj_t * btn, lv_style_t * style ,int x, int y)
//lv_obj_t * btn = lv_btn_create(obj);
//lv_label_set_text(RTC_time, "YEEEHAW");
lv_obj_set_size(btn, x, y);
lv_obj_center(btn);
lv_obj_add_event_cb(btn, btn_event_cb, LV_EVENT_CLICKED, NULL);
label = lv_label_create(btn);
lv_label_set_text(label, "000"); //sets text to somthing before the RTC kicks in with the actual value
lv_obj_add_style(label, &style, 0);
lv_obj_center(label);
static void USBbtn_event_cb(lv_event_t * USB_btn){
if (err) {
while (1);
struct dirent *ent;
int dirIndex = 0;
int res = 0;
char buf[100];
int i=0;
double Cal[10];
//while (i<8){
Serial.println(i);
i++;
if (msd.connected()){
fclose(f);
Aa2=get_cal_val("Aa2");
Aa1=get_cal_val("Aa1");
Aa0=get_cal_val("Aa0");
Ba2=get_cal_val("Ba2");
Ba1=1;
Ba0=0;
Ca2=0;
Ca1=1;
Ca0=0;
Serial.println(Aa2);
}else{
Aa2=0;
Aa1=1;
Aa0=0;
Ba2=0;
Ba1=1;
Ba0=0;
Ca2=0;
Ca1=1;
Ca0=0;
return -1;
For whatever reason, everything works until the program hits the fgets that is supposed to parse the calibration data on line 646. I think it probably has something to do with how I have something declared since this isn't the only spot where I am opening and closing files, but I am at a bit of a loss. I tried commenting on just about everything except for the button press event to get the new data, but it still had the same issue.
Any suggestions would be greatly appreciated.
