Reading configuration from SD Card
I modified the SD sketch to read WIFI setting from a file named CONFIG.TXT. The text file’s content format is SETTING=VALUE, Ex.
SSID=WIFIAP01
KEY=WIFIAP01PASS
I managed to separate the SETTING and VALUE with this code:
#include <SPI.h>
#include <SD.h>
File myFile;
void readWifiConfig() {
  Serial.println("Initializing SD card...");
  char temp;
  bool isSetting = true;
  if (!SD.begin(4)) {
    Serial.println("Initialization failed!");
    return;
  Serial.println("Initialization done.");
  myFile = SD.open("CONFIG.TXT");
  if (myFile) {
    Serial.println("CONFIG.TXT");
    while (myFile.available()) {
      temp = myFile.read();
      if (isSetting == true) {
        if (temp == '=') {
          Serial.print("="); //Writes '=' to console
          isSetting  = false;
        else {
          Serial.print(temp); //Writes SETTING part to console
      else {
        if (temp == '\n' || temp == '\r') {
          isSetting = true;
        else {
          Serial.print(temp); //Writes VALUE part to console
    myFile.close();
    Serial.println("Can't open CONFIG.TXT");
  delay(10);
  readWifiConfig();
Output:
CONFIG.TXT
SSID=WIFIAP01
KEY=WIFIAP01PASS
Do I have to append the char to a temporary char array and transfer it to final character array after reaching a newline? and if so, how do I do that?
Somehow I managed to do it but my code is un-optimized. Please let me now if I’ve done something that isn’t good.
I changed the content format to this so it’s much easier for me. (CONFIG.TXT)
%SSID%&WIFIAP001&%KEY%&PASS1234&
New code.
#include <SPI.h>
#include <SD.h>
File myFile;
char wifiSsid[63];
char wifiKey[63];
char temp;
char settingSsid[5] = "SSID";
char settingKey[4] = "KEY";
char settingTemp[10];
char valueTemp[63];
int settingTempLastPos = 0;
int valueTempLastPos = 0;
int percentCount = 0;
int andCount = 0;
bool ssidValueFound = false;
bool keyValueFound = false;
  if (!SD.begin(4)) {
    return;
  if (myFile) {
      if (temp == '%') {
        percentCount++;
        isSetting = true;
        if (percentCount == 2) {
          //Serial.println(settingTemp);
          if (strcmp(settingSsid,settingTemp) == 0) {
            Serial.println("SSID SETTING FOUND");
            //IF FOUND RAISE FLAG FOR ADDING VALUE TO SSID CHAR ARRAY
            ssidValueFound = true;
          else if (strcmp(settingKey,settingTemp) == 0) {
            Serial.println("KEY SETTING FOUND");
            keyValueFound = true;
          memset(&settingTemp[0], 0, sizeof(settingTemp));
          percentCount = 0;
      else if (temp == '&') {
        andCount++;
        isSetting = false;
        if (andCount == 2) {
          //Serial.println(valueTemp);
          if (ssidValueFound) {
            memcpy(wifiSsid,valueTemp,63);
            //Serial.println(wifiSsid);
          else if (keyValueFound) {
            memcpy(wifiKey,valueTemp,63);
            //Serial.println(wifiKey);
          memset(&valueTemp[0], 0, sizeof(valueTemp));
          andCount = 0;
      else {
        if (isSetting == true) { //setting
          settingTemp[settingTempLastPos] = temp;
          settingTempLastPos++;
        else if (isSetting == false) { //value
          valueTemp[valueTempLastPos] = temp;
          valueTempLastPos++;
    myFile.close();
  delay(10);
  readWifiConfig();
Output:
CONFIG.TXT
SSID SETTING FOUND
KEY SETTING FOUND
WIFIAP001
PASS1234
