reading data from 16f877a
hello folks,
i want to read data which is some calculation result, from 16f877a. And how i can sent this data to arduino uno for use and display.
We're going to need more details
Use Serial.read()
hello again,
i connect microphone (with amplifier) to analog pin(A0) of the 16f877a. the pic doing some calculations after the pic create the values between 40 to 100. how can i sent these values (40-100) to arduino any pin and use these values on the arduino.
Please see reply #1
Have the pic send it over serial? That part has a UART - that would be the easiest way, I think - I would hope that it would be easy to send serial data from a PIC. As suggested above.
Otherwise, you could get fancy and make the pic act as an I2C slave - but that would likely be a lot more work.
DrAzzy:
I think uart or I2C. But I dont think I2C is going to be much work.
