These are the detailed queries on the Absolute rotary encoder ( EPM50S8-1013-B-S-24 ) . Below I attached the datasheet of the encoder.
ENCODER NUMBER: EPM50S8-1013-B-S-24
ENCODER TYPE: MULTI-TURN ABSOLUTE ENCODER
OUR EXPERIENCE WITH ABSOLUTE ENCODER
· Connected encoder with Arduino
· Supplied 14v to the encoder
· Generated clock pulse of frequency 313KHz
· Clock + and Clock – pulses are shifted by 90 degrees with 5v supply from Arduino board
· Read output from Data+ and Data- pins through an oscilloscope
· Tried to digitally read from data pins. But the output was random 0s and 1s irrespective of encoder position.
· Tried to read analog values from the data pins. But the output was random.
· Tried to use counter concept (increase if rotated CW and decrease if rotated CCW). But it resulted in frequent increments of counting.
· Tried to use a bitwise shift concept. But it failed
· Tried to use the encoder library which was available in Arduino. It also doesn’t work
OUTPUT OBTAINED FROM DATA+ & DATA-
DOUBTS
· Is there any circuit connection diagram to connect the absolute encoder to any microcontroller?
· Is there any working code for this encoder with arduino?
· How to read values from data pins?
· Does it work like a counter or sends position value?
We didn’t get support from the encoder manufacturer for configuring with Arduino as they said they have only experience with PLC. Thanks in advance.
EPM50S_EN_MA_1800821_W.pdf (394 KB)
