I am fairly new to programming arduino.
I am datalogging the maximum and minimum voltage measured on A0 to a file created on an SD card.
I have managed to get the data stored onto the SD card as i had hoped but my ultimate goal is that when the arduino starts running the sketch, it opens the data file on the SD card, takes the last bits of data and then displays that data on the LCD before it moves to the main loop to look for new values.
My question is that if I am storing floats onto the SD card in a .txt file, when I read the data on the card back, what format is it in ? float,string,char?
This is my code so far, any suggestions?
This example shows how to read and write data to and from an SD card file
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
#include <SD.h>
#include <SPI.h>
#include <Wire.h>
#include <Statistic.h>
Sd2Card card;
SdVolume volume;
SdFile root;
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
const int inputPin = 7; //input pin for switch
const int ledPin = 8; //LED connected to pin 8 to show new maximum value
const int chipSelect = 4;
Statistic myStats;
myStats.clear(); //explicitly start clean
lcd.begin(16,2);
lcd.backlight();
lcd.clear();
pinMode(ledPin, OUTPUT);
pinMode(inputPin, INPUT);
digitalWrite(inputPin,HIGH);
//-------------------------------- INITIALIZE SD CARD ---------------------------------------------------------
Serial.print("Initializing SD card...");
pinMode(10, OUTPUT);
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("* is a card is inserted?");
Serial.println("* Is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
return;
Serial.println("Wiring is correct and a card is present.");
if(!SD.begin(4)){
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
File myFile = SD.open("Max.txt", FILE_WRITE);// re-open the file for reading:
if (myFile)
String header = ("Max Data , Min Data");
myFile.println(header);
myFile.close();// close the file
Serial.println(header);
Serial.println("error opening max.txt");// if the file didn't open, print an error:
int sensorValue = analogRead(A0); //read the A1 pin value (ADC Value)
//Serial.print(sensorValue);
float voltage= (sensorValue * 0.01992); //convert the value to a true voltage.
lcd.setCursor(0,0); //set the cursor to the end of line 2
lcd.print(voltage); //print the voltage
lcd.setCursor(0,1); //set the cursor to the end of line 1
lcd.print("VDC"); //print a label for the voltage
delay(100); //this delay makes the display readout more stable and not flash
myStats.add(voltage);
float value1 = myStats.maximum();
float value2 = myStats.minimum();
String dataString = String(value1) + " , " + String(value2);
if (myFile)
myFile.println(dataString);
myFile.close();
Serial.println (dataString);
Serial.println("Couldnt open File");
delay(2000);
if (myFile)
while(myFile.available())
int output = (myFile.read());
myFile.close();
Serial.println (output);
Serial.println("Couldnt read File");
//-------------------------------- MAXIMUM VALUE -----------------------------------------------------------------------------
//-------------------------------- MINIMUM VALUE -----------------------------------------------------------------------------
