reading data from an sd card
I am trying to read data from sd card and want to calculate the average of the particular data I required.
Given below is my code.
  SD card read/write
 This example shows how to read and write data to and from an SD card file
 The circuit:
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
 created   Nov 2010
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
File myFile, myFile1;
int CS_pin=4;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
   pinMode(CS_pin,OUTPUT);
  Serial.print("Initializing SD card...");
  if (!SD.begin(CS_pin)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
 double dtemp[4488], sum=0, val=0, avg;
int i, count=0, j=0, counter, do_nothing;
  // re-open the file for reading:
  myFile = SD.open("edited3.txt");
  if (myFile) {
    Serial.println("edited3.txt:");
for (i = 0;((myFile.available()) && (i <1122)); i++) {
if(myFile.read()=='A')
  count=count + 1;
  dtemp[i]=myFile.parseFloat();
  Serial.println(dtemp[i]);
  val=0.43+dtemp[i];
  Serial.println(val);
  sum=sum+val;
  Serial.println(sum);
else if(myFile.read()=='B')
  count=count + 1;
  val=1.32+dtemp[i];
  sum=sum+val;
else  if(myFile.read()=='C')
  count=count + 1;
  val=5.24+dtemp[i];
  sum=sum+val;
else if(myFile.read()=='D')
  count=count + 1;
  val=11.79+dtemp[i];
  sum=sum+val;
else if(myFile.read()=='E')
  count=count + 1;
  val=22.28+dtemp[i];
  sum=sum+val;
else if(myFile.read()=='F')
  count=count + 1;
  val=29.7+dtemp[i];
  sum=sum+val;
  do_nothing=1;
//counter= count-j;
Serial.print(F("Sum:"));
Serial.print(F("Count:"));
Serial.println(count);
avg=sum/count;
Serial.print(F("Average:"));
Serial.println(avg);
    myFile.close();
    // if the file didn't open, print an error:
    Serial.println("error opening edited3.txt");
  // nothing happens after setup
Below I have attached the text file which I am trying to read from the sd card. But the problem is that all the values that I require for average calculation won’t get read. Below is my serial monitor output:
Initializing SD card…initialization done.
edited3.txt:
3.16
8.40
8.40
3.07
8.31
16.71
3.35
8.59
25.30
3.26
8.50
33.80
3.35
8.59
42.39
-1.73
10.06
52.45
-1.04
4.20
56.65
1.67
6.91
63.56
2.27
7.51
71.07
2.53
7.77
78.84
2.89
8.13
86.97
3.07
8.31
95.28
3.35
8.59
103.87
Sum:103.87
Count:13
Average:7.99
I have 30 readings from which only 13 are being read. HELP!
edited3.txt (1.09 KB)
On which Arduino? 4488 doubles uses 17952 bytes of SRAM, of the 2048 bytes that most Arduinos have.
(Do) (you) (have) (a) (parentheses) (fetish) (?)
Read a character. If it is not an A, read another one. See if it’s a B. If not, read another one, and see if it’s a C.
Do you not see that that is nonsense? Read ONE character. Compare it to A, B, C, etc.
You WILL need save the character in a variable.
