I'm working on a project involving a programmable coin acceptor, but I'm running into problems getting the Arduino to read the data from the coin acceptor.
to set up the coin acceptor, but I'm still having no luck.
I've attached my code below. Is there something I'm missing/not getting? When I put a coin through the acceptor, the acceptor recognizes the coin, but the Arduino isn't picking anything up.
// Use the softwareserial library to create a new "soft" serial port
// for the display. This prevents display corruption when uploading code.
#include <SoftwareSerial.h>
#define CACC 3
// Attach the serial display's RX line to digital pin 2
SoftwareSerial mySerial(3,2); // pin 2 = TX, pin 3 = RX (unused)
long lcdSwitch = 0;
int lcdState = 0;
int coin = 0;
volatile int pulses = 0;
volatile long timeLastPulse = 0;
mySerial.begin(9600); // set up serial port for 9600 baud
delay(500); // wait for display to boot up
pinMode(CACC, INPUT);
attachInterrupt(digitalPinToInterrupt(CACC), coinISR, RISING);
mySerial.write(254); // cursor to beginning of first line
mySerial.write(128);
long timeFromLastPulse = millis() - timeLastPulse;
if (pulses > 0 && timeFromLastPulse > 200)
// sequence of pulses stopped; determine the coin type;
if (pulses == 10)
Serial.println("Received dime (2 pulses)");
//money += .1;
else if (pulses == 20)
Serial.println("Received quarter (5 pulses)");
//money += .25;
else if (pulses == 30)
Serial.println("Received looney (10 pulses)");
//money += 1.0;
else if (pulses == 40)
Serial.println("Received tooney (15 pulses)");
//money += 2.0;
Serial.print("Unknown coin: ");
Serial.print(pulses);
Serial.println(" pulses");
pulses = 0;
if((millis() - lcdSwitch) > 5000ul)
lcdSwitch = millis();
lcdState++;
lcdState %= 2;
if(lcdState == 0)
mySerial.write("Gold Rush Draw ");
mySerial.write("Terminal ");
else if (lcdState == 1)
mySerial.write("Please insert ");
mySerial.write("$1 or $2 coin ");
void coinISR()
pulses++;
timeLastPulse = millis();
You're using code designed to work with one coin acceptor, but that's not the coin accepter you're using...
It looks like the coin accepter you're using has switches to configure the format that it outputs data in - have you done that in accordance with the manual?
for another, i can tell that they are displaying because they are interrupting what the LCD screen is already displaying but they are only flashing on the screen for a brief moment. How do I display the new text and not the old text?
#define CACC 3
long lcdSwitch = 0;
int lcdState = 0;
int coin = 0;
if (pulses == 10)
mySerial.write("Credits: 1/2 ");
mySerial.write("Please Insert $1");
//money += .1;
//money += .25;
mySerial.write("Please Enter ");
mySerial.write("Eligible Number ");
//money += 1.0;
//money += 2.0;
pulses = 0;
lcdState++;
lcdState %= 2;
if(lcdState == 0)
void coinISR()
pulses++;
Because the new text flashes for an instant, I know that the coin acceptor is reading the data properly. Now my issue is that the way that my text is set up.
