Sorry this post is so short. I'm on my iPhone about to be at work.
Is it possible to store data on a SD card using a computer, hook it up to an arduino using a shield, then send it to a device using a rs232 to TTL converter?
Any ideas about how to do this in code using the uFat library?
I don't think ufat or ufat2 can handle reading the data, it can get directory information but doesn't seem to have a read file method. Take a look at fat16lib it does file reads very easily.
Thanks for the links you guys. Do you know if it's possible to read data from a SD card then use xmodem to transfer the data from an arduino to an external device.
It is certainly possible. The XMODEM protocol is a software protocol, so you do not need any hardware other than the Arduino's built-in hardware serial support (and of course an SD shield or PCB for your project, but that is irrelevant to the XMODEM code).
XMODEM is one of the simplest protocols -- with the corresponding limitations that come with that -- so I imagine you could fit it into an Atmega 328, even with an SD library in the chip too.
Sorry, I just had to point you here:
Practical Arduino is sweet, Jon found a way to write/read/check everything about a USB flash drive! He can check all the disk space and whatnot!
