reading data from serial port
Hello,
i try to read data from a serial port and converting it to a unsigned short.
this works so far.
but when i wan't to send a file to the board (1280 bytes)
it stalls at aproximate 440 bytes (the counter i stall's at 222 or 221)
what could it be ?
Below is the program code, later on i which to use the native usb port on my DUE, but for now i stick with the programming port (or i keep switching my usb cable)
the purpose is to load a image from serial port and display it on the tft.
#include <UTFT.h>
extern uint8_t SmallFont[];
UTFT myGLCD(CTE36);   // Remember to change the model parameter to suit your display module!
  while (!Serial);
  myGLCD.InitLCD();
  myGLCD.setFont(SmallFont);
  myGLCD.clrScr();
  unsigned short image[1280];
  int i=0, l=0;
  byte highbyte,y;
  y=0;
  i=0;
  myGLCD.setColor(255,0,0);
  myGLCD.print("Waiting for data",0,0);
  while(i < 640){
    if(Serial.available())
    myGLCD.printNumI(l,0,10);
    myGLCD.printNumI(i,0,20);
    l++;
    switch (y)
       case 1:{                                        // if y=1 then load the lowbyte of the unsigned short
        image[i]=(Serial.read() + (highbyte << 8));   // put the lowbyte and higbyte in the image array
        i++;
        y=0;
      case 0: {                                        // if y=0 load highbyte of the unsgned short
        highbyte=Serial.read();
        y=1;
  myGLCD.print("done",0,210);
  myGLCD.drawBitmap(100,100,32,20,image);
If there is at least one byte available, read both of them.
I don't think so.
Hi ageurtse
I was facinated by your post because your code, although unvenventional, looks like it should be able to download your 1280 bytes correctly before it started again through loop. I cannot comment on the GLCD part as I do not have one. I tried this on an Arduino Uno and found that it could, in fact, download the 1280 bytes if I sent them from processing one at a time. However, I could create a very similar problem to yours by setting the bauds rates to a different value at either end e.g. 9600 on processing to match the 115200 on the Arduino and I wondered if that was causing your problem?
Mrs Z
[Edit] I can also get the problem to happen if I start sending the data to the Arduino before it is ready to receive it.
