Reading data from SQL with ethernet module(enc28j60)
I need to ensure data flow in SQL using the ethernet module of this program.
//Communication protocol : For mode state in binary; 77-> AUTOMATIC, 78->MANUEL, 79 → UNKNOWN STATE
//Communication protocol : For counting state; 67-> add +1 to counting
#define pinManuel A0
#define pinAutomatic A1
#define pinMengeneStart A3
enum machineState { automatic = 0, manuel = 1, unknown = 2 };
machineState retVal;
static unsigned int voltageThresh = 805;
static unsigned int voltageMax = 1123;
unsigned int uinPulseCounter;
unsigned int uinTimeDifference;
unsigned int uinOldTime;
unsigned int uinFirstTime;
float fMengeneVal;
bool mbSignalState;
char ModeState;
char CountSend;
bool mbTimerRun;
//Start with unknown mode
retVal = unknown;
//Set mode state with char
ModeState = { ‘M’ };
//Set sending protocol to ‘C’
CountSend = { ‘C’ };
//Timer run false
mbTimerRun = false;
//Start communication
Serial.begin(57600);
fMengeneVal = analogRead(pinMengeneStart);
if (fMengeneVal >= voltageThresh && fMengeneVal < voltageMax)
Serial.print(CountSend);
Serial.print("\n");
Serial.print(ModeState + CheckWhichMode());
Serial.print("\n");
// Serial.print(“Mengene Volt:”);
//Serial.print(fMengeneVal);
//Serial.print("\n");
CountPulse();
Serial.print(“Ürün Sayısı:”);
Serial.print(uinPulseCounter);
Serial.print("\n");
int CheckWhichMode()
float manuelVal = analogRead(pinManuel);
float automaticVal = analogRead(pinAutomatic);
if ( manuelVal < voltageMax && manuelVal >= voltageThresh )
retVal = manuel;
return retVal;
else if ( automaticVal < voltageMax && automaticVal >= voltageThresh )
retVal = automatic;
return retVal;
retVal = unknown;
return retVal;
void CountPulse()
uinFirstTime = millis();
mbSignalState = true;
uinFirstTime = uinFirstTime - uinOldTime;
Serial.print(“Enjeksiyon süresi:”);
Serial.print(uinFirstTime);
Serial.print("\n");
while (mbSignalState)
delay(10);
if (analogRead(pinMengeneStart) < voltageThresh) {
mbSignalState = false;
uinOldTime = millis();
uinTimeDifference = uinOldTime - uinFirstTime ;
Serial.print(“Robot çevrimi:”);
Serial.print(uinTimeDifference);
Serial.print("\n");
uinPulseCounter++;
I would appreciate if you help…
