I am integrating thingspeak and arduino plus Esp8266 mean making a simple project which contain my android app to update the thingspeak channel and then want to read the data of that channel via arduino uno. the android parts works fine but at the arduino side i got stuck and unable to read the channel data via esp8266(attached to my arduino uno).
Here is my code.any help would be appreciated.
it shows in serial monitor connecting to thingspeak.com and show nothing next.
#include "WiFiEsp.h"
// Emulate Serial1 on pins 6/7 if not present
#ifndef HAVE_HWSERIAL1
#include "SoftwareSerial.h"
SoftwareSerial Serial1(2,3); // RX, TX
#endif
char ssid[] = "M T G"; // your network SSID (name)
char pass[] = "androidGUII"; // your network password
int status = WL_IDLE_STATUS; // the Wifi radio's status
char server[] = "arduino.cc";
// Initialize the Ethernet client object
WiFiEspClient client;
static const char* host = "api.thingspeak.com";
static const char* apiKey = "H359MYV0P0KFG2VS";
// initialize serial for debugging
// initialize serial for ESP module
Serial1.begin(9600);
// initialize ESP module
WiFi.init(&Serial1);
// check for the presence of the shield
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue
while (true);
// attempt to connect to WiFi network
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network
status = WiFi.begin(ssid, pass);
// you're connected now, so print out the data
Serial.println("You're connected to the network");
printWifiStatus();
const int httpPort = 80;
if (!client.connect(host, httpPort)) {
Serial.println("connection failed");
return;
client.println("GET /channels/421932/feeds.json?api_key=H359MYV0P0KFG2VS&results=2 HTTP/1.1");
while (client.available() == 0); // wait till something comes in; you may want to add a timeout here
Serial.println(client.read());
client.stop(); // close socket
delay(10000);
void printWifiStatus()
// print the SSID of the network you're attached to
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength
long rssi = WiFi.RSSI();
Serial.print("Signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
