Reading data sent *from* an Bluetooth LE module
Hi
I'd like to send data from a HM-10 Bluetooth 4 module controlled using an Arduino. However, I can't seem to find a terminal app that could at least display the data received on the slave. I've tried the following:
  • BlueTerm on Android: it won't connect (possibly because it's not designed to connect to BLE devices)
  • LightBlue on OSX: it connects, but it doesn't display data
I'm not an active Windows and Linux user, so I'm not aware of available options; however, I'd be willing to try anything!
Any idea?
Thanks
This is probably just a procedural matter. Blueterm is as good as anything, there should be no problem with BT4, and it is generally simpler to fly with Android.
You might find the following background notes useful
http://homepages.ihug.com.au/~npyner/Arduino/GUIDE_2BT.pdf
http://homepages.ihug.com.au/~npyner/Arduino/BT_2_WAY.ino
