HI
I have painted myself into a corner by offering to fit 3 bigger led displays to a friends machine that has 2 inch 7seg displays.
The displays I have are 7x5 alphanumeric unfortunatley driven by MAX7219..
The orig display has 3 x HC164 latchless shift registers, and I must leave this working, so I can tap into the data and clock feeds.
I bought home one of the displays and knocked up a test jig to send segment patterns with shiftout ( with no latch ) which works fine, but I have no idea what data rate is used in situ ( and I had to sell my scope )
#define data 18
#define clock 17
int delaytime = 500;
// I got these patterns from the existing wiring between the chips and the 7seg led displays
byte zero = B10001000;
byte one = B11101011;
byte two = B01001100;
byte three = B01001001;
byte four = B00101011;
byte five = B00011001;
byte six = B00011000;
byte seven = B11001011;
byte eight = B00001000;
byte nine = B00001001;
pinMode(clock, OUTPUT); // make the clock pin an output
pinMode(data , OUTPUT); // make the data pin an output3
{ // shiftOut(data, clock, LSBFIRST, B01000000);
shiftOut(data, clock, LSBFIRST, zero);
delay(delaytime);
// shiftOut(data, clock, LSBFIRST, zero);
// delay(delaytime);
shiftOut(data, clock, LSBFIRST, one);
delay(delaytime);
shiftOut(data, clock, LSBFIRST, two);
delay(delaytime);
shiftOut(data, clock, LSBFIRST, three);
delay(delaytime);
shiftOut(data, clock, LSBFIRST, four);
delay(delaytime);
shiftOut(data, clock, LSBFIRST, five);
delay(delaytime);
shiftOut(data, clock, LSBFIRST, six);
delay(delaytime);
shiftOut(data, clock, LSBFIRST, seven);
delay(delaytime);
shiftOut(data, clock, LSBFIRST, eight);
delay(delaytime);
shiftOut(data, clock, LSBFIRST, nine);
delay(delaytime
I seem to be stuck just thinking about how to convert the 3 lots of serial bytes back into something I can use in a switch case routine to refer to my 5x7 matrix array patterns.
Its not a simple serial read, with its clock and data signals, and I cannot get shift(in) working.
Any suggestions ? I think my 73 years are catching up with me !
