Reading digital sensor goes wrong
I'm trying to read a IR phototransistor. I'm using digital reading, via 4. The white LED which should go on is at pin 11. Another IR LED is just on continuously.
The IR phototransistor is connected via a 10K resistor, at the sensor (so +) side.
When I point the IR LED at the IR sensor, the output is 0 (like expected). But when disabled the led or block the beam, the output is like this:
1
1
1
1
1
1
0
0
0
0
0
0
0
It should be continously be 1, because i block the beam. What do I do wrong?
My code:
#define LED 11
#define BEAM 4
byte i;
  pinMode(LED,OUTPUT);
  pinMode(BEAM,INPUT);
  digitalWrite(LED,LOW);
  digitalWrite(LED,digitalRead(BEAM));
  Serial.println(digitalRead(BEAM));
  delay(100);
Can you get rid of your LED on pin 11? I don't see a current-limiting resistor with that LED BTW. Maybe its too bright, emitting enough IR to trigger your phototransistor. Make it simple, one IR LED, one phototransistor. I don't see why you have to have that other LED.
Considering the extremely high impedence of an arduino input pin the voltage downstream of a phototransistor wired open ended through a resistor is going to be very hit and miss. It should be wired similar to this :
The test point being the arduino input.
I totally mentally-swapped the LED and the phototransistor! You're right pluggy. His phototransistor needs the 5V and resistor.
