Reading Distance in Micron
Hello,
I am working on a project in which I need to calculate un-even surface of a metal disc.I need to know if I can do it using ardiuno. minimum range it should be able to read is 2 micron. what sensor I should use for it.
any help will be appreciated.
Thanks
Would one of these meet your specifications?
https://www.mitutoyo.com/products/small-tool-instruments-and-data-management/indicators/digimatic-indicators/
I need one which I can interface with ardiuno
Here is a link to an arduino library for Mitutoyo Digimatic protocol
Which I'm kind of excited to find since I have a Digimatic indicator around here somewhere.
EXACTLY what features of the surface are you wanting to calculate? Do you actually want to MEASURE something? If you are attempting to determine the roughness of the surface, that is always done by comparison to a standard roughness plate.
If you are attempting to determine the roughness of the surface, that is sometimes done by comparison to a standard roughness plate, or by using a profilometer, of which contact or non-contact (optical) flavors are available.
Some profilometers have RS232 or other types of output that an Arduino could read.
I need to know if a rotating disc is uneven from any place.
somehow need to detect the thickness of a rotating metal disc.
I am trying to find a sensor which can provide data in micron (0.0002 mm) and can be interface with arduino. I have seen TOF10120 but not sure if it can provide reading based on my requirement.
Any help will be appreciated.
Thanks
Try replacing the term "uneven" with "smooth" or "optically flat". That might give better search results.
"Runout" is a common term for rotating part unevenness for machining and metrology.
You need to be more clear about what you are trying to achieve.
"A" implies you want runout or, possibly, roughness.
"B" implies you want to know the variations in the thickness of the disc.
Which is it?
2 micron is different than 0.0002mm.
Are you looking for micron-scale resolution output or to measure micron scale features? Typical metrology/gauging uses gauges with resolution 1/10 the size of the tolerance/feature you are trying to measure. You might need a 0.2um resolution gauge to measure a 2um feature reliably.
I am really sorry for my poor description and knowledge about the matter.
but as you stated I need to look a little deeper in the subject to understand the difference between micron and um. however I have been asked to build a machine to check the surface of a brake drum, and I think the machine used for its testing called brake surface testing machine.
I have seen a similar machine which rotates, (there are three laser sensors attached with that) and identify the area from where its not flat or un-even. the requirement I received is that I need to identify it its 0.0002mm.
So first I would like to know if there is a sensor which can provide such data to arduino.
I am thinking to test TOF10120 sensor which states its range from 10 to 180cm, but i am not sure if it can meet my requirement.
Hope I am able to clarify what I want.
and Thanks for your patience. @DaveEvans @DaveX
With a range like 10-180cm, I'm certain that the TOF10120 will not meet your needs. The blurb on Amazon advertises 5% accuracy, so that's about 9mm.
I've not worked in a brake shop. but for this purpose the machinists I worked with would use a "Last word" mechanical dial indicator with a 0.75mm range and 0.01 resolution divisions.
ARE YOU REALLY SURE YOU KNOW WHAT YOU WANT??? Measuring the surface of a brake drum is different from measuring that surface or run out of a brake DISK!!!
You need to give more thought to what you were really asked to do.
EDIT: I think someone is making a joke with you. A disk for a disk brake may be as smooth as glass in a mirror and as flat as industry can make it. BUT!!!!! As soon as it is used for braking, the surface will no longer be smooth because the brake pads work by friction and that makes the metal surface wear away. The friction produces heat which makes the brake disk warp, so it is no longer even. All brakes have tolerance built into the design to allow for warping.
Automated Brake Disc Inspection Machine01.pdf (336.1 KB)
could you please check what is the purpose of this machine? I am just trying to understand things which helps me to achieve what I want, and I dont think there is any harm in learning, no matter how childish is the Question, for me its a step for learning.
note: this is a machine that need to be built. I dint see it physically, nor know much detail about it, whatever I got from a person who is the middle man and want me to do the stuff for his client.
So I am still sorry, if my question are not relevant.
Thanks
Designing and building an automated brake rotor inspection machine (like the one shown in your PDF) "from scratch" would be a major research and development project - a very challenging task even for experienced engineers. And the process, including the hardware, is likely to be very expensive.
Nothing personal, but that doesn't fit my image of you, based on your posts. I could be wrong.
If you are getting paid to do this, then you should consider posting in the "gigs and collaborations" part of this forum, where you can pass on some of your compensation to a more experienced person, who may be able to take this on.
If you really want to continue to pursue this yourself, I recommend calling (yes, on the phone) a number of sensor manufacturers, describing your project, and asking for recommendations. Here's one to start with: Laser sensors for metals and rough surfaces
And there is NOTHING there about the surface quality of the disk.
Hi
Im looking for a sensor within the same area of measure. I work for a medical company that would like to measure movement in xyz axis within 1mm +/- 0,5mm. Max range doesn’t need to be more than 1-5 cm. Does this exist somewhere? At this point I almost don’t care if it’s 10€ or 10000€. I’m not able to Google anything.
However I see this new 3D printer bambu labs use LiDAR with wich seems like a quite good accuracy, but except for that I can not find anything.
https://www.mitutoyo.com/products/small-tool-instruments-and-data-management/indicators/digimatic-indicators/absolute-digimatic-indicator-id-u/
Thanks, I know about these, but I need it to be contactless( ie, LiDAR other lasers)
