Reading DS18B20+ temperatures
After a few day of “playing” I debugged working program for cyclic reading temperatures from DS18B20+ sensors.
The function
int my_putc(char c, FILE *t){
  Serial.write(c);
//tft.print(c);
//SoftwareSerialLCD.print(c);
function is very interesting and allows output to the any display device without any major modifications of the program.
// This Arduino sketch reads DS18B20/DS18B20+ "1-Wire" digital temperature sensors at BUS.
//you can use any unused digital input
#define ONE_WIRE_BUS 3
#include <OneWire.h>
#include <DallasTemperature.h>
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
#define TEMPERATURE_PRECISION 12
//#define TEMPERATURE_PRECISION 11
//#define TEMPERATURE_PRECISION 10
//#define TEMPERATURE_PRECISION 9
#define MAX_SENSORS 3
DeviceAddress Thermometer[MAX_SENSORS];
float Temperature[MAX_SENSORS];
byte numberOfDevices;
byte Limit;
#define FLOAT_A 3
#define FLOAT_B 3
#if !defined(DEVICE_DISCONNECTED)
#define DEVICE_DISCONNECTED -127
#endif
  Serial.write(c);
void printAddress(DeviceAddress deviceAddress){
  printf("%02X-%02X-%02X-%02X-%02X-%02X-%02X-%02X\r\n", deviceAddress[0], deviceAddress[1], deviceAddress[2], deviceAddress[3], deviceAddress[4], deviceAddress[5], deviceAddress[6], deviceAddress[7]);
void setup(void){
  fdevopen( &my_putc, 0);
  sensors.begin();
  printf("Locating devices...");
  numberOfDevices = sensors.getDeviceCount();
  printf("Found %d devices.\r\n", numberOfDevices);
  printf("Parasite power is: ");
  if (sensors.isParasitePowerMode()){
    printf("ON\r\n");
  else{
    printf("OFF\r\n");
  if (numberOfDevices > MAX_SENSORS){
    Limit = MAX_SENSORS;
  else{
    Limit = numberOfDevices;
  for(byte index=0; index<Limit; index++){
    if(sensors.getAddress(Thermometer[index], index)){
      printf("\r\nDevice %d address:\r\n", index);
      printAddress(Thermometer[index]);
      printf("Setting resolution to %d\r\n",TEMPERATURE_PRECISION);
      sensors.setResolution(Thermometer[index], TEMPERATURE_PRECISION);
      delay(750/ (1 << (12-TEMPERATURE_PRECISION)));
      printf("Resolution actually set to: %d\r\n",sensors.getResolution(Thermometer[index]));
    else{
      printf("Found ghost device at %d but could not detect address. Check power and cabling!\r\n",String(index));
  printf("\r\nGetting temperatures...\r\n");
void loop(void){
  sensors.requestTemperatures();
    Temperature[index] = sensors.getTempC(Thermometer[index]);
    if (Temperature[index] == DEVICE_DISCONNECTED) {
      printf("Error!");
    else {
      static char dtostrfbuffer[15];
      dtostrf(Temperature[index], FLOAT_A, FLOAT_B, dtostrfbuffer);
      printf("%s \xB0""C  ",dtostrfbuffer);
    switch (TEMPERATURE_PRECISION){
    case 9:
      delay(94);
    case 10:
      delay(188);
    case 11:
      delay(375);
    case 12:
    default:
      delay(750);
Wiring is very simply, such as
Nice example code!
I checked it, and wondered if you are using the correct location for the delay. In your code, you wait for each sensor to convert, so adding a large delay. But the delay is already in the library, called with the function requestTemperatures(). So you can get good readings with just one delay after printing all temps. Code change: relocate on singe }; a few lines up in both loop and setup.
Keep up the good work!
michelv:
I don’t know if the delay is necessary. I took a part of another program and implement it in my loop.
Note:
Program requires OneWire.h and DallasTemperature.h (download latest version)
