Reading DTMF Data On PortC
Hi All,
I am trying to read dtmf data using M8870 ic with UNO.
data pin's A, B, C, D are connected to pin A0 to A3.
I change A0 to A3 to digital input's. Here is the code.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
byte dtmf_data;  // hold dtmf data
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(A0,INPUT);
  pinMode(A1,INPUT);
  pinMode(A2,INPUT);
  pinMode(A3,INPUT);
  pinMode(A4,INPUT);
// the loop routine runs over and over again forever:
  dtmf_data  == (PINC)&0x0F;
  Serial.println(dtmf_data);
my problem is no bcd code is detecting on portc.
correct function is, when i press button 1 then serial terminal shows continuous char 1 & this information will change according to button.
Thanks
Hi All,
Problem solved.
Here is the mistake.
i write
instead of
dtmf_data = (PINC)&0x0F;
Thanks
Hi All !
I am using pin2,3,5 & 6 using as digital output but they are not working according to command.
Are these pins are busy with some other functions.
How to solve this ?
Thanks
Not in the code you posted.
How to solve this ?
There's a clue above...
Hello Sir,
UNO Pin 2,3,5 & 6 pin are driving L298 motor driving ic.
2 motors are connected. Motors does not run according to command.
To solve this problem, 1st i remove L298 & put 4 led's on pin-2,3,5 & 6 pin.
I am surprised everything works perfect.
Now i remove led's & put again L298, now motor does not follow command.
I test L298 with manual sending data for reverse & forword direction & its work perfect.
Now it may be only power supply issue.
Now going to test it.
Thanks
