Reading EEPROM with programmer outputs wrong data
I'm having trouble reading EEPROM from ATTiny841 via avrdude and an AVR-ISP-MkII.
When I read the EEPROM using the programmer I get (I'll only give first 128 bytes):
3A 32 30 30 30 30 30 30 30 30 30 30 30 30 30 30
30 30 30 30 30 30 30 30 30 46 46 46 46 46 46 46
46 46 46 46 46 46 46 46 46 46 46 46 46 46 46 46
46 46 46 46 46 46 46 46 46 46 38 0D 0A 3A 32 30
30 30 32 30 30 30 46 46 46 46 46 46 46 46 46 46
If I write code for the micro to read the EEPROM internally and spit it out over UART I get:
00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
I'm confident that the UART output is correct as I specifically set the 8 bytes to 0x00 and the EEPROM was previously 'erased' to 0xFF.
I've tried the EEPROM programmer read with both the AVR-ISP and a USB-asp programmer and get the same results. The avrdude command I'm using is:
avrdude -C../etc/avrdude.conf -v -pattiny841 -cstk500v2 -Pusb -Ueeprom:r:eep.hex:i
I have previously written and read EEPROM in this way. The only thing I've done recently is upgrade my Arduino IDE to 1.8.12
Any ideas?
For USBasp try
-cUSBasp
or
-cAVRISP
for AVR-ISP.
It certainly ought to work...
Oh wait...
That output looks to be correct, but getting rendered wrong (it's the hex codes for the characters that represent that data, 0x30 is a 0, 0x46 is an F, 0x0D 0x0A is a CR LF newline
Great spotting @DrAzzy!
My (not so) trusty hex editor is the problem! That's quite an embarrassing mistake... but thank you very much for spotting it for me.
You are outputting in intel hex format, so it would be an ascii file, not binary.
if you want binary use -Ueeprom:r:eep.hex:r although I would not use the .hex file extension in that case.
