In my project I use a stepper motor and spindle to compress a spring.
To measure the position/displacement the spring is compressed I placed on the axle of the stepper motor an encoder disk with 300LPI resoltuion.
A full steppermotor turn is 200 steps and 2 mm displacement of compression.
I need to know the value at 1 mm displacement so I need to increment/decrement the encoder value of 1070.
So motor is turning by one step or constant rotation but my stepcounter does not increment/decrement.
I guess I am overlooking some basics after 10 hours of struckle. ![]()
Any idea how simple the solution would be?
Thanks, Paco
#include <Stepper.h>
//Left = Down
//Right = Up
// Stepper has 200 revolutions for 360 degrees = 2 mm pitch we use 1 mm steps = 100 steps = 1070 pulses from the encoder
const int stepsPerRevolution = 100;
Stepper myStepper(stepsPerRevolution, 4,5,6,7); // we use digital pins 4,5,6,7 with L298 stepper driver
boolean LeftTurnSingle = 0;
boolean RightTurnSingle = 0;
boolean LeftTurnConstant = 0;
boolean RightTurnConstant = 0;
boolean StartState = 0;
boolean RecordingState = 0;
boolean ReturnState = 0;
int incomingByte = 0; // for incoming serial data
int StepCounter = 100;
int Analog2 = 16; // Use analog port on shield for push button to control movement and direction
int Analog3 = 17; // Use analog port on shield for push button to control movement and direction
int enablePin10= 10; //pin to enable/disable coil power
int enablePin11= 11; //pin to enable/disable coil power
enum PinAssignments
encoderPinA = 2, // rigth
encoderPinB = 3, // left
long encoderPos = 100000; // a starting counterposition for the encoder
long encoderPosOld = 100000;
unsigned int lastReportedPos = 1; // change management
static boolean rotating = false; // debounce management
// interrupt service routine vars for encoder disk
boolean A_set = false;
boolean B_set = false;
pinMode(enablePin10,OUTPUT);
pinMode(enablePin11,OUTPUT);
myStepper.setSpeed(400); // set the stepperspeed at xxx rpm:
pinMode(encoderPinA, INPUT);
pinMode(encoderPinB, INPUT);
// turn on pullup resistors for encoder
digitalWrite(encoderPinA, HIGH);
digitalWrite(encoderPinB, HIGH);
// encoder pin on interrupt 0 (pin 2)
attachInterrupt(0, doEncoderA, CHANGE);
// encoder pin on interrupt 1 (pin 3)
attachInterrupt(1, doEncoderB, CHANGE);
LeftTurnSingle = digitalRead(Analog3);
RightTurnSingle = digitalRead(Analog2);
Serial.print("A,");
Serial.println(StepCounter);
Serial.print("B,");
Serial.println(encoderPos,DEC);
//Serial.print("C,");
//Serial.println("datafromloadcell");
if (encoderPos >= (encoderPosOld + 1070)) //if the value is 1070 higher then last known raise stepcounter by 1
StepCounter = StepCounter + 1;
if (encoderPos <= (encoderPosOld - 1070)) //if the value is 1070 lower then last known reduce stepcounter by 1
StepCounter = StepCounter - 1;
if (LeftTurnSingle == 1)
digitalWrite(enablePin10,HIGH);
digitalWrite(enablePin11,HIGH);
myStepper.step(stepsPerRevolution); // Do a left turn of 100 steps
else if (RightTurnSingle == 1)
myStepper.step(stepsPerRevolution * -1); // Do a right turn of 100 steps
digitalWrite(enablePin10,LOW);
digitalWrite(enablePin11,LOW);
encoderPosOld = encoderPos;
// Interrupt on A changing state
void doEncoderA(){
// debounce
if ( rotating ); //removed the 1 us delay // wait a little until the bouncing is done
// Test transition, did things really change?
if( digitalRead(encoderPinA) != A_set ) { // debounce once more
A_set = !A_set;
// adjust counter + if A leads B
if ( A_set && !B_set )
encoderPos += 1;
rotating = false; // no more debouncing until loop() hits again
// Interrupt on B changing state, same as A above
void doEncoderB(){
if( digitalRead(encoderPinB) != B_set ) {
B_set = !B_set;
// adjust counter - 1 if B leads A
if( B_set && !A_set )
encoderPos -= 1;
rotating = false;
