Reading energy meter with RS485 MODBUS protocol
Hello everyone
I am currently working on a project for which I have to read data from an energy meter through RS485 communication.
Energy meter: http://.farnell.com/datasheets/2166982.pdf
Communication protocol energy meter: https://.enika.cz/data/files/produkty/energy%20m/CP/EM100%20and%20ET100%20series%20-%20Modbus%20serial%20protocol%20-%20rev.2.6%20-%20141114.pdf
(put 'www' after 'https://', I could not post more than 2 links in my thread)
The board I am using is an Arduino Leonardo board, but it is mounted inside of a PLC enclosure. The PLC is a product from industrial shields, a company that makes Arduino based PLC's for a low price. This PLC allows communication through RS485 when the switch zones are setup correctly. A MAX485 module is used for this.
Arduino PLC: https://www.industrialshields.com/web/content?model=ir.attachment&field=datas&id=185658&
I am currently trying to read 2 registers from the energy meter. Holding register 4 and 5, those registers contain the active power. I think my wiring is correct and the parameters are also set up correctly. But every time I run my code, I do not get any response from the energy meter. Reading the parameter "result" gives me the error code E2, which means that I did not get any response from my slave.
I have attached the settings for my energy meter, my code and pictures of my connection.
Settings energy meter:
Parity: even
Stop bit: 1
Slave ID: 1
Baud rate: 9600
Code:
`#include <ModbusMaster.h>
ModbusMaster node;
uint16_t baudrate = 9600L;
Serial.begin(baudrate, SERIAL_8E1);
node.begin(1, Serial);
uint8_t result;
uint16_t data[2];
result = node.readHoldingRegisters(4, 2);
Serial.println(" ");
if (result == node.ku8MBSuccess)
Serial.println("succes");
Serial.print("no succes, error code: ");
Serial.println(result, HEX);
Pictures:
https://we.tl/t-kCGbYQ3P26
The cable I just an ethernet cable that I cut open and stripped on both sides.
This is my first post on the forum so I hope that I provided enough information. If not, please let me know. If anyone would be able to help me, that would be greatly appreciated!
Thanks in advance.
