Reading frequency on Uno vs Mega, differences
I’m using the following code to read a square wave.
http://www.gammon.com.au/forum/?id=11504
// Frequency timer
// Author: Nick Gammon
// Date: 10th February 2012
// Input: Pin D2
volatile boolean first;
volatile boolean triggered;
volatile unsigned long overflowCount;
volatile unsigned long startTime;
volatile unsigned long finishTime;
// here on rising edge
void isr ()
  unsigned int counter = TCNT1;  // quickly save it
  // wait until we noticed last one
  if (triggered)
    return;
  if (first)
    startTime = (overflowCount << 16) + counter;
    first = false;
    return;
  finishTime = (overflowCount << 16) + counter;
  triggered = true;
  detachInterrupt(0);
}  // end of isr
// timer overflows (every 65536 counts)
ISR (TIMER1_OVF_vect)
  overflowCount++;
}  // end of TIMER1_OVF_vect
void prepareForInterrupts ()
  // get ready for next time
  EIFR = bit (INTF0);  // clear flag for interrupt 0
  first = true;
  triggered = false;  // re-arm for next time
  attachInterrupt(0, isr, RISING);
  }  // end of prepareForInterrupts
void setup ()
  Serial.println("Frequency Counter");
  // reset Timer 1
  TCCR1A = 0;
  TCCR1B = 0;
  // Timer 1 - interrupt on overflow
  TIMSK1 = bit (TOIE1);   // enable Timer1 Interrupt
  // zero it
  TCNT1 = 0;
  overflowCount = 0;
  // start Timer 1
  TCCR1B =  bit (CS10);  //  no prescaling
  // set up for interrupts
  prepareForInterrupts ();
  } // end of setup
void loop ()
  if (!triggered)
    return;
  unsigned long elapsedTime = finishTime - startTime;
  float freq = F_CPU / float (elapsedTime);  // each tick is 62.5 nS at 16 MHz
  Serial.print ("Took: ");
  Serial.print (elapsedTime);
  Serial.print (" counts. ");
  Serial.print ("Frequency: ");
  Serial.print (freq);
  Serial.println (" Hz. ");
  // so we can read it
  delay (500);
}   // end of loop
This works perfectly for the UNO. With the MEGA it reads high.
Input 100Hz: Uno returns 100Hz, MEGA returns ~117Hz
Input 200Hz: Uno returns 200Hz, MEGA returns ~280Hz
Input 1000Hz: Uno returns 1000Hz, MEGA returns ~1700Hz
I tried a different Mega, an official one from the Arduino store. Same results.
I thought maybe there’s a problem with Timer 1 with the Mega? I tried switching to Timer 3, not sure if I did it right.
// Frequency timer
// Input: Pin D2
void isr ()
  unsigned int counter = TCNT3;  // quickly save it
  if (triggered)
    return;
  if (first)
    first = false;
    return;
  triggered = true;
  detachInterrupt(0);
}  // end of isr
ISR (TIMER3_OVF_vect)
  overflowCount++;
  first = true;
void setup ()
  // reset Timer 1
  TCCR3A = 0;
  TCCR3B = 0;
  TIMSK3 = bit (TOIE3);   // enable Timer1 Interrupt
  // zero it
  TCNT3 = 0;
  overflowCount = 0;
  // start Timer 1
  TCCR3B =  bit (CS10);  //  no prescaling
  } // end of setup
void loop ()
  if (!triggered)
    return;
  delay (500);
}   // end of loop
Still the same results. Not sure what’s going on, anyone ever encountered this when switching to a MEGA?
Have you checked the datasheet? The Mega will have different registers to Atmega328.
stoutfiles: Not sure what's going on, anyone ever encountered this when switching to a MEGA?
Maybe a problem with your signal: is signal ground and Arduino ground connected and at the same ground level?
What about switching to a different frequency counting code?
This one counts hardware interrupts (UNO example: pin-2, interrupt-0) using the micros() function for timing:
#define FREQPIN 2
#define FREQINT 0
// volative variables for interrupt handling
volatile uint16_t count_ISR;
volatile uint32_t time_ISR;
void freqCounter() // interrupt handling
  count_ISR++;
  time_ISR=micros();
float readFrequency() {  // calculating frequency from counts and time
  static uint32_t lastFreqTime;
  noInterrupts();
  uint16_t freqCount= count_ISR;
  count_ISR=0;
  uint32_t freqTime= time_ISR-lastFreqTime;
  lastFreqTime= time_ISR;
  interrupts();
  return 1000000.0*freqCount/freqTime;
  attachInterrupt(0,freqCounter,RISING);
  // Comment out the following line if you put a signal on pin-2
  tone(2,1000); // generate a test tone on pin-2
  static uint32_t lastTime;
  if (millis()-lastTime>=1000) // Calculate and show result once every second
    lastTime+=1000;
    float f= readFrequency();
    Serial.println(f);
No additional hardware timer needed. Limits: Should be working without any problems up to frequencies out of the audio spectrum.
[quote author=Nick Gammon link=msg=2140373 date=1426408986] Have you checked the datasheet? The Mega will have different registers to Atmega328. [/quote]
Ah yes, INTF0 does not apply to Pin D2. Changed to INTF4 and it now works.
jurs: Maybe a problem with your signal: is signal ground and Arduino ground connected and at the same ground level?
#define FREQPIN 2
#define FREQINT 0
// volative variables for interrupt handling volatile uint16_t count_ISR; volatile uint32_t time_ISR;
void freqCounter() // interrupt handling {   count_ISR++;   time_ISR=micros(); }
float readFrequency() {  // calculating frequency from counts and time   static uint32_t lastFreqTime;   noInterrupts();   uint16_t freqCount= count_ISR;   count_ISR=0;   uint32_t freqTime= time_ISR-lastFreqTime;   lastFreqTime= time_ISR;   interrupts();   return 1000000.0*freqCount/freqTime; }
void setup() {   Serial.begin(9600);   attachInterrupt(0,freqCounter,RISING);   // Comment out the following line if you put a signal on pin-2   tone(2,1000); // generate a test tone on pin-2 }
void loop() {   static uint32_t lastTime;   if (millis()-lastTime>=1000) // Calculate and show result once every second   {     lastTime+=1000;     float f= readFrequency();     Serial.println(f);   } }
I'm not quite sure how to explain this, but the device that gives me my signal has glitches where sometimes I'll get a frequency twice as high as I should. I can see that with Nick's code, and I can use a running median to filter it out.
Any other code I use averages those spikes in and it's always higher than it should be. At least that's what I think is happening.
