Hi everyone!
I need to read from an Analog port at a fixed "low" frequency (125Hz-250Hz)... I don't need to read faster than that and report the data through Serial to a PC...
I know I can do the read using the analogRead() and also know I can set a pre-scalar but I don't know how to make the frequency adjustable. Another question I wanted to ask is, wouldn't it be better to a store a bunch of values in an array and then send the array through Serial Port?! I don't know if sending every value individually will crash at this speed.
Have a look at how millis() is used to manage timing without blocking in Several things at a time
...R
xykudyax:
Hi everyone!
analogRead() takes about 100 microseconds (0.0001 s) to read an analog input, so the maximum reading rate is about 10,000 times a second.
for good resolution between reads you may want to use micros() instead of millis().
since your data is two bytes, if you use a fast baud rate (i.e. 115200) you can probably keep up easily sending data packet real-time.
void loop(void)
int newValue = analogRead(myPin); // ~100 microseconds
Serial.write(highByte(newValue)); // high order byte ~10 - 15 microseconds??
Serial.write(lowByte(newValue)); // low order byte ~10 - 15 microseconds??
Serial.write('\n'); // new line
delayMicroseconds(adjustedValueToCompensateForFunctionTimesAbove);
Sending a newline after two bytes of binary would be a waste of 1/3 of the bandwidth. Since only 2 bits of the high byte are used you can use the upper 6 bits for synchronization:
void loop(void) {
Serial.write(highByte(newValue) | 0xA8); // high order byte ~10 - 15 microseconds??
Then the PC can look at the top 6 bits and get a very good indication of high-byte vs low-byte and re-sync.
Read highByte.
If (highByte & 0xFC != 0xA8) read highByte again
Read lowByte.
Possibly better would be to put 5 bits in each byte and use the upper 3 bits to indicate if it is high-byte or low-byte.
