Hello, I am using an Arduino M0 pro and have set up an interrupt timer so I can periodically read from some sensors via I2C inside of the interrupt handler. However, the I2C commands will not work inside the ISR I think the timer interrupts are working as they will blink LEDs with no problems. I had a similar issue a while back on an UNO but could fix it by briefly enabling interrupts inside the ISR using interrupts() while the sensors were read then disabling them again with noInterrupts(). This does not seem to work on the M0 pro for some reason. I would be very grateful if someone knows what is going on!
An interrupt can be used to set a few variables and maybe change an output pin.
Don't use the Serial library in a interrupt, and neither any LCD, SD, I2C or other libraries.
Stay away from interrupts, unless you really need them. For example when decoding a rotary encoder.
Koepel, Thanks very much for your input, and I see your point. However its bugging me that it won't work when the same thing worked like a charm on the uno...
It did not "work like a charm". You were just lucky that enabling interrupts whilst in an ISR did not cause a problem.
What do you think might happen if you enabled interrupts when in an ISR and an interrupt occured, maybe even the same type of interrupt that the ISR was already servicing ?
Use the ISR to set a flag indicating that it's time to read the sensors. Then, pick up that flag in the loop() function and do your I2C operations there with interrupts enabled. Don't forget to clear the flag.
UKHeliBob:
Multi-level interrupts is what I'm used to when I was programming MCS51 microcontrollers; it was implemented in hardware though. I don't really see the problem where a lower priority interrupt can be interrupted by a higher priority interrupt.
In the AVRs the same can be achieved by selectively disabling interrupts before reactivating the global interrupt enable.
I have to admit that I have not had a need for a multi-level interrupt in the AVR (Arduino) environment.
